Camaro Research Group Discussion => Originality => Topic started by: 69 Zee on August 21, 2014, 08:05:31 PM
Title: What's the correct Alternator bracket for a 69 Z/28
Post by: 69 Zee on August 21, 2014, 08:05:31 PM
Hello all,
Thought I try here for an answer to what are the correct Alternator brackets for a 69 Z/28 with the original alternator.  I was given some parts for a 69 Z that I have and I happen to get 2 different front lower Alternator brackets.   They have different bents in them at different locations.  Ones got to be the correct one.  What would the other be for and why.  I have the factory #837 Alternator as well.  Are the brackets different because the alternators are different from one another.. an #837 from a regular Alt ?
Thanks for any help.
Title: Re: What's the correct Alternator bracket for a 69 Z/28
Post by: 69Z28-RS on August 21, 2014, 09:23:01 PM
I am certainly not positive about this, but since automatic cars did not require SMOG, and straight shifts did, the different brackets might have been to compensate for the thickness of the smog bracket, that I believe used the same fastener (if present)??   Is this why some cars have to have a 'spacer washer' depending on their configuration??
Post by: 69 Zee on August 21, 2014, 09:29:20 PM
Quote from: 69Z28-RS on August 21, 2014, 09:23:01 PM
Hmmm.. good question also.  I was wondering about that spacer also. I have the smog brackets and pump but no spacer.  If I don't find an answer I'll be keeping both brackets and see which one plays out and fits the set up correctly once assembled.
Post by: 6667ss138 on August 21, 2014, 10:59:11 PM
Darrell, I'll take mine off this weekend and take pictures and post for you to compare.
Post by: 69 Zee on August 22, 2014, 07:23:45 AM
Quote from: 6667ss138 on August 21, 2014, 10:59:11 PM
Thanks Len,  No rush.  You still running the smog.  Inn wondering if it has anything to do with the smog which I'll be using.
Post by: zman1969 on September 18, 2014, 11:03:14 AM
I dont know which is correct but from what I know there is a weird bushing that goes through the bracket for the air pump-so the pulley lines up- maybe one is stamped different and doesent use the bushing? I also would like to see pics of correct one
Post by: TODD on September 18, 2014, 07:59:20 PM
Hmm doesn't the Z28 smog pump have a spacer under the pulley also for alignment?
Never have seen pics of an original set-up showing correct parts for alignment.
Anyone have pics and dimension for pulley spacer as well?
Post by: rszmjt on September 18, 2014, 11:35:49 PM
Quote from: TODD on September 18, 2014, 07:59:20 PM
Nope, 1969 Z28 does not use a spacer, 458 pulley goes rite against the white plastic fan hub. The Upper bracket is Correct, the lower bracket is for 74 up. My car has original smog, I will post a picture tomorrow
Post by: 69 Zee on September 18, 2014, 11:44:37 PM
You just beat me to the punch on the pulley spacer rszmjt ...lol.  Yes the top bracket in my first pic is the correct one.  Len (6667ss138) had pointed out to me about a spacer that's pressed into his bracket in the most central hole of his bracket (which mine is missing).  Is that for the smog pump attachment ?
Post by: rszmjt on September 18, 2014, 11:53:43 PM
Quote from: 69 Zee on September 18, 2014, 11:44:37 PM
Yes The upper smog pump bolt goes through the spacer into the pump.
Post by: 6667ss138 on September 19, 2014, 07:27:15 AM
Quote from: zman1969 on September 18, 2014, 11:03:14 AM
I posted a picture of mine with the bushing still there over on Darrell's other "Garage/Barn find" thread thats showing all the parts and numbers from his car. Its on page 9. reply 133
http://www.camaros.org/forum/index.php?topic=12511.120
Post by: 69Z28-RS on September 19, 2014, 08:09:01 AM
Quote from: rszmjt on September 18, 2014, 11:53:43 PM
Can you (or someone) with an car with smog, that's been there since the factory, take a photograph of the bracket and spacer? and the assembly as on the engine for those of us attempting to add smog back to our engines...  Thanks..
Post by: 69 Zee on September 19, 2014, 05:14:52 PM
Quote from: 69Z28-RS on September 19, 2014, 08:09:01 AM
x2 with you Gary,   Since mine is all disassembled I'd like to see these brackets fixed to one another also.  I'm also guessing that I'll need to find a bracket with that bushing already pressed in because I'm missing my bushing  :(   I know the bushing has a relief cut but finding the correct diameters (inside/outside) might be tough I'd think.
Post by: 1968 Z28 on September 19, 2014, 07:16:58 PM
There is a split spacer on AMK that states that it fits 69-73 GM Smog Pumps.  There is no GM part number associated with it but the specs are.....
.39 ID x .51 Length x .49 OD
Might find someone that has an original and get them to check to see if theirs matches the specs on this one.
Post by: rszmjt on September 19, 2014, 08:51:18 PM
Seems to me the bushing might have a flared type end that rests against the smog pump, and it is seamed. I never had a chance to take a picture today, car is up on a storage hoist.  I will tomorrow and post a picture.
Post by: rszmjt on September 20, 2014, 01:23:54 PM
Bsg does have a small flared end against the pump.
Post by: Hans L on September 22, 2014, 03:25:01 PM
Here's the one on my car, before it was refinished:
(http://i1061.photobucket.com/albums/t478/jwlittooy/AIRBrackets2_zps9728c2d4.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/AIRBrackets2_zps9728c2d4.jpg.html)
Post by: rszmjt on September 23, 2014, 09:42:24 PM
Thats the correct bushing for 69-72 Camaro, Here is another shot of it.
BTW 68-72 Chev truck uses the same bushing in the lower alternator brkt, also 68-77 Corvette.
Post by: RS_COPO_Canuck on May 01, 2015, 07:51:18 AM
How about big block? Here is my lower alternator bracket....bushing missing. Does the BB use the same bushing as the SB? Who sells them? I heard AMK does but can't find them on their site. Thanks
