Camaro Research Group Discussion => Originality => Topic started by: Camarocards on June 15, 2014, 08:58:27 AM
Title: TH400 Kickdown Harness Clip
Post by: Camarocards on June 15, 2014, 08:58:27 AM
Does anyone know who might sell the clip that secures the kickdown harness to the transmission on a TH400? I'm not having much luck in locating one. The GM part number is 1368774. Item 2 in the attached picture. Item 3, screw, (p/n 3837950) is also pretty tough to find. This is for a '68 L35.
A picture from a members car might also help.
Bob
Title: Re: TH400 Kickdown Harness Clip
Post by: big iron on June 19, 2014, 08:33:01 PM
Bob,
No reproduction of the clip is being made.
Best bet would be to check the junk yards for big GM 67, 68 and 69 cars and trucks,  they all used T400 transmissions.
You could also run add on TC.
I saw no response so figured I would at least give you some ideas.
Bob
PS Does your BB 68 have AC ?
Post by: Camarocards on June 19, 2014, 08:50:28 PM
Bob,
Thanks for the reply. Much appreciated!
I was over a friends house last night who happened to have a TH400 lying around. We checked it for the clip and lo and behold there was one on it! Now, I'm not 100% certain it's correct but I've searched the web high and low and have come up completely empty on what this darn clip is suppose to look like.  He was kind enough to give me both the clip and screw, which BTW is another tough one to find! It happens to be the same screw that secures the fuel tank sending unit ground wire to frame rail but it's a real odd size that neither AMK or no else for that matter, offers.
So until I can confirm what the clip actually looks like I'm going to run with what I now have. It'll be a while before the engine and tranny are in the car so my hunt continues.  :)
BTW...My car does not have AC.
Once again, thanks for the reply.
Bob
Post by: ryanmaple on March 15, 2018, 03:41:18 PM
is this one correct for 67?
Post by: big iron on April 09, 2018, 02:50:43 PM
That is the correct clip and screw.
Bob
