Camaro Research Group Discussion => Restoration => Topic started by: Camarocards on February 22, 2014, 08:16:53 PM
Title: Galvanizing a Fuel Tank
Post by: Camarocards on February 22, 2014, 08:16:53 PM
Has anyone ever had their fuel tank galvanized 50% Tin/50% Zinc)? I have an extremely clean original date coded tank that I'd like to bring back to a factory looking appearance and do not want to paint it. I realize the original tanks were Tern (20% Tin/80% Lead) coated and this formulation has long since been stopped due to the hazards of lead.
Bob
Title: Re: Galvanizing a Fuel Tank
Post by: ZLP955 on February 22, 2014, 08:38:25 PM
Bob, I have been involved with hot-dip galvanizing of structural steel sections, but never thin-section base metal such as a fuel tank. Nor can I recall the % make-up of material used. Therefore, can't comment with any direct knowledge, but my thoughts are:
- the process may distort the shape of the tank.
- the existing holes in the tank (such as filler neck and sender hole) while large diameter, may not be best positioned to allow fast draining of the zinc on removal from the tank.
- the finish may not be suitable to you from a visual point of view, being an industrial coating as opposed to an architectural finish.
Having said that, I believe the reproduction tanks (such as those made by Spectra) have a gal finish, but not sure of the process used; it may be that they are produced from a cold-galvanized material.....
Perhaps best to contact a local company that does this process and discuss?
Post by: Camarocards on February 22, 2014, 09:35:10 PM
Thanks for your comments Tim. I have sent an e-mail to a local company that specializes in galvanizing (http://www.kornsgalvanizing.com/). I'll let you know what they say.
Post by: BULLITT65 on February 22, 2014, 10:28:06 PM
Where is the big red Gorilla on this one ????  COOK where are ya buddy, aren't you the plating guru around these parts?? ;D
Post by: Sauron327 on February 23, 2014, 06:48:07 AM
Spectra tanks are Ni Terne coated.
Quote from: ZLP955 on February 22, 2014, 08:38:25 PM
Post by: ZLP955 on February 23, 2014, 02:13:34 PM
Quote from: Sauron327 on February 23, 2014, 06:48:07 AM
What's the process for that Scott? I take it that it involves at least a Nickel coating.
Post by: cook_dw on February 24, 2014, 09:04:14 AM
Quote from: ZLP955 on February 23, 2014, 02:13:34 PM
Stolen from Team Camaro: - http://www.camaros.net/forums/showthread.php?t=207355 (http://www.camaros.net/forums/showthread.php?t=207355)
The annealed cold-rolled steel sheet is first processed to apply a thin flash coating of electrodeposited nickel, and then it's given a hot-dip lead-tin alloy coating. The nickel base coat gives Ni-Terne steel an extra measure of corrosion resistance compared to U.S. Steel's regular "Terne" steel sheet and also compared to traditional galvanizing, which isn't readily available anymore. It should also be pointed out that the Ni-Terne coating protects both interior and exterior surfaces of the fuel tank from surface corrosion.
You have 2 different types of "galvanizing".  Just by doing a little google searching I found a couple of videos to give a better understanding of the processes.
Cold - which can be done electrically or in other cases as paint which is enriched with zinc to give it that added protection.
Cold Dip Galvanization (http://www.youtube.com/watch?v=_0y-ppm5JX0)
Pros - cost, and application
Cons - looks like paint (paint version - I am still working on trying to perfect this process along with the electro process)
Hot - which is where the zinc (or lead/tin as mentioned previously) is heated until molten and then the part or steel is submerged slowly and stays there for several minutes and slowly raised out and a layer of zinc is bonded to the metal.
Hot Dip Galvanization (http://www.youtube.com/watch?v=i-VcyOkOmbc)
Pros - it will look factory
Cons - cost
I am currently experimenting with the two cold processes mentioned above and trying to locate a company locally for pricing on "Hot Dipping".
Quote from: BULLITT65 on February 22, 2014, 10:28:06 PM
I am certainly NO expert.  I enjoy learning processes and how to accomplish them myself and for others if the opportunity arises.  My apologies for not seeing this sooner.  I was working on my car all weekend getting the headliner installed along with the diff ready to go back under the car and removing the tank for this same process as mentioned by the OP.   ;D
If I have missed something on the processes or explaination please correct me so everyone can be educated.  Thanks, Darrell
Post by: Camarocards on February 24, 2014, 12:44:33 PM
Just a quick follow-up from my original post.
I just heard back from the company mentioned in reply 2. They told me that they will not re-galvanize anything that they did not original galvanize. Not sure why but it's back to the drawing board.  :(
Bob
Post by: ko-lek-tor on February 24, 2014, 12:59:42 PM
Bob,
Probably not the answer you are looking for. I took my gas tank to a radiator shop to get the neck re-soldered a few months back. At that time, I asked about having tank re-dipped, re-tinned ?(terminology). This shop is well know in doing rare and difficult antique radiator restoration work and the owner advertises in Hemmings and Old Cars publications. The owner said he could re-tin small areas to repair tank, but he could not do entire tank. So, if there are just some areas that tin has deteriorated, consider just having those areas done and leave the original as is. You can bring back the sheen with some fine steel wool or 600 wet sand paper. Here is a link to the radiator shop I use:  http://www.yellowpages.com/wilmington-oh/mip/powell-radiator-service-5173186  You may call him and he may know a place since he does resto work.
Post by: Camarocards on February 24, 2014, 01:12:12 PM
James,
Yea, you're right.  Not the answer I was hoping for. Thanks for the tip I'll look into it.
My tank is in superb shape and after removing the 45 year old undercoating I was pleasantly surprised to see how well the underlying metal was preserved. The undercoating did exactly what it was suppose to do. The top and sides of the tank where naturally, the undercoating did not get to, has surface rust which, as you have suggested, I'm cleaning up with steel wool. It's just a long laborious painful process. I was hoping for an easier way to get it back to the factory look.
Bob
Post by: big iron on February 24, 2014, 03:10:01 PM
I just checked several shops in the Jax. Fl. area and they all said they would not hot dip gal. gas tanks  because of the high temperatures involved in the process. The only way to get the spangled finish we are looking for is with the hot dipped process, so I guess I will soda blast my tank and follow up with 4-0 steel wool and a coat of clear.
If anyone finds a shop that will hot dip tanks I would like to know.
Bob
Post by: cook_dw on February 25, 2014, 09:35:04 AM
I have talked to 2 different galvanizing companies in TN and no one will touch a gas tank.  I am working on a painting procedure that might make it look like galvanized.  Once I get all the bugs worked out I will post my results.
Post by: BULLITT65 on February 26, 2014, 12:21:47 PM
thanks Cook
Post by: KurtS on March 01, 2014, 03:00:33 PM
Shops may be avoiding the old tanks cause they have lead in the coating. It would contaminate their process.
Post by: janobyte on March 01, 2014, 04:47:22 PM
I think eventually cook is going to figure out the process for making gold in his shop-- :D
So if the tanks in good shape under the goop ,strip it ,coat it with Shark skin and leave it ?
Post by: cook_dw on March 25, 2014, 06:47:33 AM
Quote from: janobyte on March 01, 2014, 04:47:22 PM
I wish jano...
Here is the my tank I finished up a couple weeks ago.  Its not perfect but I think its as close as Ill be able to get it.
(http://img.photobucket.com/albums/v687/superslow/1967%20Camaro/DSC03357_zps8f77c5d4.jpg) (http://smg.photobucket.com/user/superslow/media/1967%20Camaro/DSC03357_zps8f77c5d4.jpg.html)
Post by: Camarocards on March 25, 2014, 06:56:22 AM
Darrell,
Very nice! What did you do to get that type of finish?
Bob
Post by: BULLITT65 on March 25, 2014, 02:58:49 PM
spray paint?
Post by: cook_dw on March 25, 2014, 08:10:45 PM
Yes it was spray paint.  I used a base of gray primer.  Once dry I misted it lightly with water then used duplicolor chrome and misted the tank with the water still on the tank.  Once paint was dry I wiped off the water and added another mist of the chrome paint.  What you see is the result.  It took several attempts but I think it is close to what I have at work as far as galvanized metal for reference.  Remember that the look of galvanized will be different depending the process.  Here is what the tank looked like before.
(http://img.photobucket.com/albums/v687/superslow/1967%20Camaro/image_zps3013b90e.jpg) (http://smg.photobucket.com/user/superslow/media/1967%20Camaro/image_zps3013b90e.jpg.html)
Post by: BULLITT65 on March 25, 2014, 09:01:37 PM
WTG, thanks for the break down on the process. I like the end product.
Post by: cook_dw on March 26, 2014, 11:18:59 AM
Thanks.  Like I said it is far from perfect but I am satisfied with it.
Post by: HawkX66 on March 26, 2014, 02:19:37 PM
Quote from: cook_dw on March 26, 2014, 11:18:59 AM
In the end, that's all that matters.
