Can I get 2 pictures of the following for a '67:
1. Rear brake hose to body mount tab/hard line.
2. Rear brake hose to diffential mount tab.
I just replaced the hose in the same orientation as was on the car-but it seems tight (not much play). Would like to confirm the old one was replaced correctly when the springs were updated to multis. Thanks Chris.
In the AIM UPC 5 Sheet B2 gives you a pretty good idea of the setup. I'll check tonight to see if I have any pics
Got it. Thanks.
67-68 junction block and brackets are the same but 2 different hoses are listed, 68 longer because of multi leafs.
Bob
Thanks Bob - I think you are spot on with that. I tried orienting the brackets a few different ways - always the same result. I think going with the '68 multi spring version is the answer - for now (might go back to the singles at some point - and I'll have the right hose :))
Thanks again - Chris
