What is the difference between hood part numbers 3938617 and 3938619? Thanks
617 is your standard flat hood 67 to 69 hood, 619 is the SS hood with the power bulge and openings for the hood ornaments (the big block SS velocity stacks, or small block louvered trim pieces). 3949708 is the 69 Ducted (cowl induction) hood.
So this is a big block hood?
(http://i174.photobucket.com/albums/w112/68zproject/SSRSideEdited.jpg) (http://s174.photobucket.com/user/68zproject/media/SSRSideEdited.jpg.html)
Quote from: 68Zproject on December 31, 2013, 12:52:36 AM
Not necessarily, depending on the build date it could be a small block... http://www.camaros.org/forum/index.php?topic=6470.0
A true '67 SS hood had a different part number than the later '68-'69 version. The 'stacks' required punched holes for the drains.
Quote from: william on December 31, 2013, 04:44:22 PM
And original 67 hoods didn't have the drain holes and rubber drain spouts added like in 68-69. That's why so many rotted out from the inside-out.
Here is a real nos 67 ss hood 3898129
'Plum',
And no drain holes and rubber spouts, correct?
correct no drain holes
