I was checking the decoding numbers section of this site and couldn't find an answer, maybe I missed it but I was wondering if the VIN number and cowl tag date match up?
VIN nor500026
Trim tag date of 08A
The end of month reporting for approximate highest assigned VINs is only listed from September of 1968 for the '69 model year, but one of the core CRG guys will know. But that VIN denotes an extremely early build; do you own the car?
That's a real early car. I haven't seen that build date before, but it is probably real. Got a pic of the tag?
Any drivetrain original?
Check that cowl tag build date again, probably not a A after the 8. I have one vin lower than that, and several between that one an 500100, and none of them are 08A build week tags. Don't have a single Norwood built 08A car. Maybe a pilot car? Would need to see a picture of the tag itself.
Is the number above a body number (its in that format but there is no 500000 series body numbers) or a VIN which would just be N500026?
Quote from: KurtS on December 01, 2013, 09:16:59 AM
Sorry my bad! It was late last night when I was typing in the numbers and the trim tag date should be 08D not 08A
The whole VIN is 12437NOR500026: I'm got this from the owner of the car over the phone so I have not seen it myself.
I don't own the car and it is VERY rough but the color and deluxe interior peeked my interest. Then I seen the O8D build date which I knew was early and it just kind of caught my attention. It does have an engine(small block), trans (auto) and 10 bolt rear in it but I have no idea if they are the born with drive train. It looks as if the rivets for the tag has been changed was the main reason I was asking & even as rough as it is I might try to make a deal and restore it.
I have a picture of the trim tag as a word document but I'm not sure how to attach it on here.
thanks again!
email it to me (my email address is in my profile to the left) and I'll post it for you.
Thanks Ed!
I sent it to your e-mail.
Here's the tag. By the way, I'm going to move this tread to the Decoding Numbers section.
