Orphans - documentation or VIN-stamped drivetrains - in search of the original cars => 1969 - Orphans => Topic started by: BULLITT65 on November 18, 2013, 04:31:40 AM
Title: 1969 Los Angles 302 block on ebay
Post by: BULLITT65 on November 18, 2013, 04:31:40 AM
A 302 on ebay vin number 19L529500 from a 69 Camaro built in L.A. ebay Auction number 231097867983
seller Jsphd72.
If this is your VIN, do your due diligence first...
Title: Re: 1969 Los Angles 302 block on ebay
Post by: ZLP955 on November 18, 2013, 06:01:32 AM
Saw that ad (I think it's been relisted at least once) and seller states it has been lightly decked.... but you can still make out the numbers. The partial is very close to my car's VIN, but not quite close enough :(
Post by: KurtS on November 21, 2013, 04:07:17 AM
I'd say it's decked and restamped.....
Post by: BULLITT65 on November 21, 2013, 12:18:10 PM
I am not going to question your knowledge or ability to spot a restamp, but I am surprised someone would go through the trouble of decking and re-stamping and then just somewhat pick a random number to stamp on a block, hoping that 1 he didn't stamp a number that somebody already has, and 2 if nobody has it that they will see his ad. Seems like a long shot on his part is all.
Post by: cook_dw on November 21, 2013, 01:40:37 PM
I would have thought the vin would NOT have been on the pad..  Hmmmmm  Was that just a NOR thing?  Pics to are crappy to tell if it good or bad for me..  Dates line up though..
Post by: BULLITT65 on November 21, 2013, 02:41:10 PM
I thought all the LA cars had it on the pad, and Norwood switched this around January 1st of 69. I am pretty sure it is on the CRG here somewhere .
The only thing I notice is it looks like the numbers for the vin were stamped separately, and other examples of original LA blocks look like the vin number was stamped with a single gang, and looks more uniform. In Jerrys book the font seems to differ slightly as well, but I have not seen nearly as many as Kurt. If it were me I would want the guy to provide a lot more pics of the stamp, and get the input from CRG before I made a trip to see it in person.
Post by: VINCE Z28 on November 23, 2013, 01:15:25 PM
I had a 09 D 68 / 69 camaro 396  L. A. car stamped by the oil filter.
Post by: BULLITT65 on November 23, 2013, 04:17:13 PM
thats good info, I see where it says Norwood started stamping down there beginning in January 69. In jerrys book it says for LOS cars they have been found as late as april with the vin appearing on the pad.
Post by: grit1210 on November 23, 2013, 07:54:46 PM
My 10C 8/9 350 LA car is stamped by the oil filter.
Post by: BULLITT65 on November 23, 2013, 08:27:43 PM
You would have thought that it would have been changed over to the filter, and then not been stamped on the pad any longer. A discrepancy in Jerrys book possibly?
Post by: firstgenaddict on May 25, 2014, 06:17:34 AM
LA conntinued to stamp the pad Norwood changed to the filter boss... If I am not mistaken it was due to LA being a GMAD plant and Norwood being a Fisher Body/ Chevrolet Assembly plant.
Post by: ZLP955 on May 25, 2014, 06:48:08 AM
A guy I know of has a well-documented early LA car with VIN 50xxxx that has the partial at the oil filter location. At the time I saw the stamp, I thought this was an odd location and checked the CRG page, which confirmed that the Van Nuys usage of the deck pad and oil filter area was inconsistent and varied between the 2 locations.
Post by: VINCE Z28 on May 25, 2014, 11:35:22 PM
VIN  L502919 by oil filter.
