Camaro Research Group Discussion => Restoration => Topic started by: Adz28 on November 04, 2013, 12:29:58 PM
Title: Re-coding an original door lock
Post by: Adz28 on November 04, 2013, 12:29:58 PM
My ignition switch (repro) key is different than my door locks. I would like to keep my original door locks, so I was wondering if it is possible for a locksmith to recode them using just the ignition key.
Title: Re: Re-coding an original door lock
Post by: Everett#2390 on November 05, 2013, 12:11:08 AM
No, if you look at the ends of the ign key and door key, one is a mirror image of the other key.
Ign key does ign switch and glovebox, door key does doors and trunk lock.
Post by: JohnZ on November 05, 2013, 12:41:41 PM
Quote from: Everett#2390 on November 05, 2013, 12:11:08 AM
I think you'll find that on a '69, the square-head key works the ignition and doors, and the oval-head key works the glove box lock and the trunk.
Post by: DAVEN1256 on November 11, 2013, 08:54:02 AM
On my '68, the same key is used for the doors and the ignition and the other key fits the trunk and glove box.
You've got nothing to lose by calling a couple of locksmiths. I am not 100% sure but I think they can be recoded.
Dave
Post by: Oaklyss on November 11, 2013, 04:08:52 PM
Yes, they can be re-coded if the ignition key fits into the door lock. About $25each.
Post by: lakeholme on November 11, 2013, 04:50:28 PM
Read  THIS  (http://www.fierofocus.com/articles/Tech%20Tip%20-%20Keying%20your%20Fiero%20alike.htm) explanation of how one guy did it.  It has to do with the grooves in the different keys....
Post by: 69pace on November 11, 2013, 08:34:32 PM
The short answer for a 69 and later is yes*
*locksmith has to actually be a locksmith with training and then they can match the pins in the ignition tumbler to the same as the doors.
Even easier if you have the original keys with the key code not knocked out.
Or documentation with the key codes, but they can work from the key you have if it is not too worn.
Post by: MyRed67 on November 12, 2013, 01:04:25 AM
67 also the Ignition and Doors should be the same.  And the Trunk and Glove Box.  My car has all the original Locks, and 1 set of original keys.  There is a 4 digit code  #L##,  #=number L=letter.   A good locksmith can cut you a set of keys from just the code.  As has been stated, it has to do with the grooves, if the Ignition key will go into the Door locks (or vice versa) then yes they can be recoded to match.  Also all of the locks and original keys have this 4 digit code stamped on them.  I would recode the Ignition to match the Doors, that way you are only recoding 1 lock.  If you recode the doors to match the Ignition, then you have to do 2.  Just my 2c's.
Post by: tom on November 12, 2013, 02:31:13 AM
Back in the 70's I took the cylinders from locks on my corvair to a local lock smith, and had him redo them. When I reinstalled them that afternoon, I had what I wanted. One key worked every lock and switch on the car. Kind of like they build them today. Wasn't real expensive, but some people thought it was stupid. I just wanted it simple.
