Camaro Research Group Discussion => General Discussion => Topic started by: KevinK on September 07, 2006, 12:59:17 PM
Title: Brake Bleed tool suggestion ... Motive vs. MityVac ????
Post by: KevinK on September 07, 2006, 12:59:17 PM
...I posted this on Team Camaro, ...but thought to ask here as well.
  Considering Brake Bleed tools, ...what is everyone else using? (if you know the model # of what you are using, ...please post)
... I'm looking at two units right now:
A Motive Kit#0250  http://store.summitracing.com/partdetail.asp?part=mvp-0250
...and a Mityvac Silverline Plus #04050.  http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=8309
...I've found better prices other than the links above, ...so the price is within $8 between the two ($70-$80).
I never heard of the Motive before, ...but I am sided towards it since it seems a bit easier to use.
...comments? ...other suggestions?
               Kevin
Title: Re: Brake Bleed tool suggestion ... Motive vs. MityVac ????
Post by: JohnZ on September 08, 2006, 01:27:08 PM
No-brainer - the Motive Products pressure bleeder is the best sixty bucks you'll ever spend; I've fought bleeding stubborn Corvette 4-piston disc brakes for years, and the MP pressure bleeder makes them a piece of cake and a one-person ten-minute job. I've tried all the other stuff (MityVac, Phoenix Injector, etc.) and none of them hold a candle to the MP setup.  :)
Post by: KevinK on September 08, 2006, 03:45:03 PM
...Glad to hear that, ...especially from you John  ;)
     ...I placed an order for the Motive yesterday
            Kevin
Post by: hotrod68 on September 08, 2006, 10:46:53 PM
Low-tech guy here--I lay a cinderblock on the brake pedal and pump it up between cylinder bleeds (chuckle).
Post by: jdv69z on September 11, 2006, 02:55:17 PM
So Kevin, where's the best place to get the Motive Poducts MVP-0250 price wise?
Jimmy V.
Post by: KevinK on September 12, 2006, 07:02:29 AM
Jimmy,
   The best price I found, and where I purchased mine was on Ebay as a Buy It Now.
     (using Google's "Froogle" search, ...there are a couple places that are close, ...but tax and shipping add up)
  Here's a link...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300026316609&ssPageName=MERC_VIC_RSII_Pr4_PcY_BIN_Stores_IT&refitem=300022843418&itemcount=4&refwidgetloc=closed_view_item&usedrule1=ItemToItem&usedrule2=StoreCatToStoreCat&refwidgettype=cross_promot_widget
