Camaro Research Group Discussion => Restoration => Topic started by: french69ssrs on October 18, 2013, 10:01:04 AM
Title: 1969 Camaro SSRS Wire Harness Restoration DIYS
Post by: french69ssrs on October 18, 2013, 10:01:04 AM
Hi All
I am Restoring my 1969 SSRS Camaro and it has been Modified/ Hacked in Various areas, Dash Harness and Engine Bay.
I have some wires broken off at the Terminals where the Turn Signal Wiring goes into the "Hamonica Connector" and was looking for these type of Male Terminal Spades.
I found them -
http://www.repairconnector.com/search.php?search_query=GM+Pak+Con+OEM&x=9&y=11
     And my Wire is a 14 gage so it will be
     GM Pak Con OEM Repair Terminal Male 16 14 AWG
http://www.repairconnector.com/products/GM-Pak%252dCon-OEM-Repair-Terminal-Male-16%252d14-AWG.html
They have a Repair Kit, I ordered it with a few Extras. I'm sure these were used for many years and across All the GM lines.
Again, Thanks
Timmy
Title: Re: 1969 Camaro SSRS Wire Harness Restoration DIYS
Post by: sixt9x33rs on October 24, 2013, 10:44:46 PM
If your wiring harness is hacked into, I would consider a new quality harness. There are a few vendors that recreate a very nice harness. That last thing you want is a fire. I have put two on Corvettes...lectric limited was one supplier and the other from a group out West. Don't recall the name.
