Camaro Research Group Discussion => Restoration => Topic started by: 67rs327 on September 05, 2013, 09:26:49 PM
Title: 327 Timing Chain Cover
Post by: 67rs327 on September 05, 2013, 09:26:49 PM
Looking to replace the timing chain cover on my '67 327/275 as I just discovered while cleaning it has developed some pin holes & is weeping oil. Bone stock orig.  engine & I'm a little confused when looking for a replacement - what I specifically need in regards to the right size? (7",8",short,deep, etc., etc.). Also - what vendor carries the best  OEM type part? No chrome! Looking for basic painted cover. Thanks
Title: Re: 327 Timing Chain Cover
Post by: Everett#2390 on September 06, 2013, 10:27:40 AM
I believe you will need the one style with the welded on scale as opposed to the bolt-on scale.
Post by: 1968 Z28 on September 06, 2013, 12:13:38 PM
Here is one example for you......
    http://www.classicmuscle.com/p-49808-327-cover-welded-tab-correct-exc-327l79.aspx (http://www.classicmuscle.com/p-49808-327-cover-welded-tab-correct-exc-327l79.aspx)
Post by: 67rs327 on September 08, 2013, 06:54:33 PM
That works! Thanks man.
Post by: KurtS on September 30, 2013, 12:05:34 PM
Depends on where the holes are, but I'd weld or braze the holes closed and use the original part.
Post by: 69Z28-RS on September 30, 2013, 12:53:36 PM
I agree with Kurt...   repair rather than replace whenever possible..  :)
Post by: 67rs327 on September 30, 2013, 08:56:36 PM
Got it. Coming off this weekend and will inspect to see what I can do to keep the orig. unit - Thanks
