Hi Guys, everything was working fine on my 68 but I noticed the other day that my horn and my key buzzer did not work anymore.
Any ideas where I should start looking?
Wires are connected properly on the horn and on the horn relay.Fuse is ok.
thanks
If you have access to another relay switch it out to confirm if it's a bad relay or not.
both trigger based on grounds that often go bad and require clean ups.
