Is the heat valve the same for all 69 small blocks with 2" and 2 1/4" headpipes or are there two different valves? What about flanges? I don't have them and need them. Found both a valve and 2 flanges but need to make sure they will fit the factory manifolds and exhaust for a 69 DZ engine.
(http://htsmall.rickscamaros.com/assets/rfg/images/size/265x265/sku/RC-62.jpg)
http://www.rickscamaros.com/1969+chevy+camaro+standard/camaro-exhaust-manifold-heat-riser-assembly-small-block-gm-1967-1974.html (http://www.rickscamaros.com/1969+chevy+camaro+standard/camaro-exhaust-manifold-heat-riser-assembly-small-block-gm-1967-1974.html)
This is the only one I know of for 1969 small blocks...though most of the ones I have seen were removed and an eliminator ring substituted or they just gutted and reinstalled the factory item by removing the flapper door and weights and a stove bolt inserted to close former axle pivot hole.
This is the heat valve I have. Looks the same doesn't it? Something is either upside down or backwards on mine I think.
Yeah the bottom picture looks right side up as the weight should be installed on the fender side, weight pointed toward the front of the vehicle. Take the top one and flip it around and see what it looks like. Both Look in good condition considering age.
Quote from: 69pace on August 01, 2013, 11:20:48 AM
Those 2 pics are of the same valve. Works perfect, just need to clean it up a bit. So as it sits in the second pic just rotate the valve 1/4 turn clockwise so the weight is parallel with the fender.
Is the Ricks pic wrong?
Quote from: 69Z28 on August 01, 2013, 12:14:07 PM
Nope, it's just shown upside-down; the flat side goes up, against the (flat) outlet flange on the manifold, with a gasket, and the chamfered side goes down, and mates with the top of the "donut".
Quote from: JohnZ on August 02, 2013, 11:36:31 AM
If you look at the pic of Ricks and mine the weigh mechanism is reversed or backwards or something. One of them is wrong it believe.
These things are problematic at best - I have not had
a good experience with any current offerings. For what it's
worth, my two, cents is that they will eventually stick, and
probably in the closed or partially closed position.
I removed them from both my '66 Chevelke and '69 Camaro
and replaced them with the donut replacements.
Unless you absolutely have to have it original, to me
the problems far outweigh the benefits. Both of my
cars start easily - and I give them a few extra seconds (10-15) at
idle when I first start them, but other than that you would not
know the heat riser valves weren't installed unless you physically
went and looked.
Quote from: 69Z28 on August 02, 2013, 11:43:29 AMIs the Ricks pic wrong?
Quote from: JohnZ on August 02, 2013, 11:36:31 AMNope, it's just shown upside-down; the flat side goes up, against the (flat) outlet flange on the manifold, with a gasket, and the chamfered side goes down, and mates with the top of the "donut".
Quote from: 69Z28 on August 01, 2013, 12:14:07 PMIf you look at the pic of Ricks and mine the weigh mechanism is reversed or backwards or something. One of them is wrong it believe.
No its the same valve - as JohnZ states there IS a top side and a bottom side of the valve. And yes it was common practice to remove or to gut the valve, and close the hole from the removed flapper axle with a standard nut and bolt. That was what was done on my vehicle by the original owner when he removed the smog pump.
Maybe your not seeing what I see. On the Ricks valve pic, the bevel for the packing donut is facing up with the weight mechanism pointing, lets say north and on the right. If you look at my second pic the flat gasket side is up with the weight mechanism pointing north and to the right. If I flip mine over 180 then the weight mechanism is on the left of the valve whereas the Ricks pic is on the right...OR...if you spin my first pic 180 either way, clockwise or counter-clockwise to match the Ricks pic the weight mechanism's are opposite.
Can you see it? I'm thinking one of these is wrong.
No I understand what you are saying but there are many repro valves out there some are flat and chamfered as original, others are chamfered on both sides. ANd they pictures are generic-interchangeable on catalog listings.
Quote from: 69pace on August 02, 2013, 09:38:57 PM
OK, I think I got it now. That pic in itself is not a good representation of what an OEM heat valve would look like for a 69 Camaro Z28.
If that's the case does mine look correct? I think the guy said it was a take off of a 71 350 270hp Corvette.
Yes I believe that John liked your examples.
Any way to tell if this valve is stuck? The more I think about it, I noticed that at the rear tips the exhaust flows better on the drivers side than passengers. So I am thinking mine might be stuck?
OE from my 68 Z
Here is a pic of Jano's and the one I picked up for comparison. Note his valve weight on the left and mine on the right. So the valve weight on mine will point to the front of the car and his will point to the rear. Different for 68 and 69? Here's a question, how is the valve oriented when installed, with the arm on the engine side or the the fender side?
Quote from: mickeystoys69RSSS on August 05, 2013, 07:36:43 PM
I always thought something odd was going on there. In the wintertime I noticed how steam would be coming out more on the driver side exhaust then the passenger side on a lot of cars when they were first started up and run in the morning. Would see it a lot with dual exhaust, not at all on single exhaust of course.
<<Here's a question, how is the valve oriented when installed, with the arm on the engine side or the the fender side?>>
Here's mine - if the weight is on the inboard side, it would probably interfere with the starter solenoid with the valve open.
Thanks John...that's the shot I was looking for. The valve I have, looking at your pic, will be at 9 o'clock where yours is at 3 o'clock and the weight will be pointing the same as yours, towards the fender well. Can I assume that even these heat valves have differences in them? Or will/should they all be the same? I was looking at my survivor 69 Impala LM1 and the valve is installed with the weight on the left as well with rams horn (center dump) manifolds.
Reason I brought this up is because I took the headers off my Z to install the manifolds about a 1000 miles ago and noticed that the passenger head pipe was pushed up tight against the floor. I'm still wondering if I even have a packing donut in there. I'm sure I do since there isn't any exhaust leaks. I hate bring this up but I felt like I needed to. Always had headers on my cars so I have never seen what I need to connect UNCUT head pipes to manifolds before. At least now I know I need to get new studs ( short and long), 2 packing donuts, 2-2" head pipe extension tubes and a flat gasket. I should be all set then.
FWIW , I used a small grinding wheel and cut/removed butterfly from riser assy.
Re-installed // Looks, and functions (weight-spring movement only ) as original, and no worry about sticking in closed position!!
In circling back to this topic, I remember reading in one of the forums someone discussing how they disassembled the heat riser valve to take out the flapper portion (without cutting it out) and then have the weight and spring still showing so it looked original. I have read through forums about heat risers, but can't find that string. Does anyone know which forum what discussion was on, or have input on how to disassemble the heat riser to take out the flapper and then reinstall for the original look? Thanks
Is THIS (http://www.camaros.org/forum/index.php?topic=9159.msg65322#msg65322) what you're looking for?
Quote from: bertfam on August 02, 2018, 10:45:03 AM
Exactly, thanks Ed.
I just bought a fuel injection car spacer. They look the same as the heat riser valve but do not have a flapper/shaft hole/weight. Just a straight thru design. No cutting or mods required.
I didn't think about the fact that the fuelies did not have heat crossovers.
I used the process Ed posted and it works. I had to cut through the flapper centers just enough using a Dremel cutoff wheel to split them so as to remove the shaft.
