Camaro Research Group Discussion => Originality => Topic started by: 69Z28 on July 10, 2013, 10:43:32 PM
Title: Exhaust manifold bolts.
Post by: 69Z28 on July 10, 2013, 10:43:32 PM
Are the exhaust manifold bolts all the same length for the 69 small block and other then the french locks were there any washers used at all? Looking to get new bolts for my 69 Z engine but need this info on washers beforehand. Thanks guys.
Title: Re: Exhaust manifold bolts.
Post by: x77-69z28 on July 11, 2013, 08:42:43 AM
Same length with thick flat washers
Post by: 69Z28 on July 11, 2013, 10:38:42 AM
Quote from: x77-69z28 on July 11, 2013, 08:42:43 AM
Thanks. Washers on the french looks too correct? Found some engine pics in this post but can't see the bolts to well to tell.
http://www.camaros.org/forum/index.php?topic=10034.0;all
Post by: Everett#2390 on July 11, 2013, 10:57:25 AM
No french locks on center bolts with flat washers, just torque them to 35 ft/lbs.
Outside pairs have flat washers and french locks and torqued to 15 ft/lbs allowing for heat/cold cycles of cast iron manifold(s).
Post by: 69Z28 on July 11, 2013, 06:17:08 PM
Yeah, gotcha on the french locks not on the center ports. Just needed to know if all the bolts got the washers including the french locks.
Any particular place to get the most correct parts or do you have to order this from there and that from another there? No one seems to carry an all in one kit.
Post by: Everett#2390 on July 11, 2013, 07:33:34 PM
AMK?
Post by: 69Z28 on July 11, 2013, 08:05:47 PM
Quote from: Everett#2390 on July 11, 2013, 07:33:34 PM
AMK?
I'll give them a look.
Post by: tmodel66 on July 11, 2013, 09:10:04 PM
Yeah I got a kit from AMK and included everything including the French locks.
Post by: 69Z28 on July 11, 2013, 11:13:46 PM
Quote from: tmodel66 on July 11, 2013, 09:10:04 PM
Hey Daniel, you have number handy? I haven't looked yet but I was going to see what I could find in the 69 AIM if is even in there.
Post by: Edgemontvillage on July 12, 2013, 12:16:47 AM
Quote from: 69Z28 on July 11, 2013, 11:13:46 PM
Gary, be aware the french locks available from AMK and other parts vendors are made of stainless steel which is incorrect. The originals were stamped untreated steel. GM still sells the steel ones (GM part# 14081241) however the stamping has changed and they are not the correct appearance for our cars. I located used ones, treated them with Evapo Rust and they work well for an unrestored car.
Post by: 69Z28 on July 12, 2013, 02:32:39 AM
Thanks Lloyd. I wasn't planning on using the stainless pieces. I just need the bolts and washers. Other than the set of french locks that are on my unmolested 46000 mile 69 Impala, I have never seen another set. I can guarantee that there probably isn't a yard within 100 miles of me that would have one old engine in it to rob those locks off of. It seems most of the smaller stuff I need to purchase I have to count on members who might have this stuff stashed away. Well...time for a WTB add on T.C.
Post by: RS_COPO_Canuck on November 15, 2016, 01:15:50 PM
For a 69 Z - should the French locks be the rounded or square tab? Also - I think only the center bolts got washers - yes? No?
Post by: KevinW on November 15, 2016, 03:05:48 PM
Don't forget A/C cars have two longer bolts for the rear compressor mount :)
Post by: elcamino72 on November 16, 2016, 05:59:46 AM
The length of the standard exhaust manifold bolts is 2 1/4".
Post by: z28z11 on November 16, 2016, 08:05:17 PM
Quote from: KevinW on November 15, 2016, 03:05:48 PM
And a spacer -
