Can someone please tell me what relay this is ? My 67 RS Headlight Doors delay opening and wont close when switched until the ignition is turned back on. Do I need a new Headlight Relay and if so is it one (or all) of the three mounted behind lights, drivers side? Many thanks
That's the horn relay. The 3 light relays should be under the drivers fender bolted to a bracket
Check out this site:
http://retro-electro.net/FAQ67.html
Near the top left of this page, run an Advanced Search using the terms 67 headlight relay. You may get a few older threads that are useful.
That is the way they should work.Mine do the same thing.As for slow operation the motors might need to be rebuilt or replaced.
