Camaro Research Group Discussion => General Discussion => Topic started by: MyRed67 on June 06, 2013, 05:58:47 PM
Title: Which Distributor was used on the L30 engine?
Post by: MyRed67 on June 06, 2013, 05:58:47 PM
  I have found conflicting lists on which Distributor was used on the L30  275 hp. 327.  I have found lists which say #1111124 and others that say #1111249.  I have a #1111249 with Date code 6H22 on the car.
Title: Re: Which Distributor was used on the L30 engine?
Post by: bertfam on June 06, 2013, 06:34:26 PM
The 1111249 is correct for a 67 L30
Post by: MyRed67 on June 06, 2013, 06:49:39 PM
Thanks Ed!  That was Quick.
Post by: 1968RSZ28 on June 06, 2013, 07:08:34 PM
Quote from: MyRed67 on June 06, 2013, 06:49:39 PM
35 minutes and 39 seconds to be exact!   ;)
Post by: MyRed67 on June 07, 2013, 12:41:39 AM
  While on this subject, how bad is 2 months earlier for this Distributor on a Oct. 26 built Engine?  Would the fact that this is fairly early build figure into equation?
Post by: bertfam on June 07, 2013, 09:51:18 AM
QuoteWhile on this subject, how bad is 2 months earlier for this Distributor on a Oct. 26 built Engine?  Would the fact that this is fairly early build figure into equation?
The distributor was installed at Flint when they assembled the engine, so it should be fairly close to the engine build date. It's within the normally accepted range, but in my opinion, a little too early.
Post by: MyRed67 on June 07, 2013, 02:47:50 PM
OK, that's pretty much what I figured.  Thanks, Ed!
