Camaro Research Group Discussion => Originality => Topic started by: Camaro3 on August 26, 2006, 01:06:31 PM
Title: Pulley's
Post by: Camaro3 on August 26, 2006, 01:06:31 PM
I have a 68 camaro with a 396/325. I had the motor rebuilt but the motor did not come with a water pump or the water pump pulley or the crankshaft pulley, can someone please help with the right pulley's to put back on the motor. I have the water pump which is the short shaft. I just need to get the right pully's.
Title: Re: Pulley's
Post by: bertfam on August 26, 2006, 01:18:22 PM
Check out the 1968 CAMARO CRG PULLEY REPORT (http://www.camaros.org/pulleys-68-28jul00.pdf). This should give you all the info you need to start scouring the countryside.
Title: Re: Pulley's
Post by: Camaro3 on August 26, 2006, 03:57:07 PM
Thanks, I did print that out, but have been trying to find them, well not so good so far. If you knwo of a place I can get them from, I would sure like to know.
Thanks again.
Title: Re: Pulley's
Post by: bertfam on August 26, 2006, 04:13:09 PM
If you're not interested in "original" pieces, RICK'S FIRST GENERATION (http://www.rickscamaros.com/cgi-local/SoftCart.exe/cgi-local/smpagegen.exe?U+scstore+fsmm8298ffdd05dd+-c+scstore.cfg+-f+0+-C+Pulleys), D&R CLASSIC (http://www.drclassic.com/index.html) (among others) sell repops of most of the pulleys that are close in appearance (with some being closer in appearance than others) to originals. Of course, it all depends on your needs, A/C -vs- NON-A/C, P.S. -vs- NON-P.S., A.I.R -vs- NON-A.I.R., etc...
Title: Re: Pulley's
Post by: firstgenaddict on August 26, 2006, 08:19:52 PM
If you are looking for originals try yenko.net, the site gets alot of traffic and there are alot of guys that have plenty of original parts... the parts are not going to be cheap... OR you can go the EBAY route...
Title: Re: Pulley's
Post by: Camaro3 on August 26, 2006, 09:14:27 PM
thanks
Title: Re: Pulley's
Post by: Tinkerr on August 26, 2006, 10:49:03 PM
What is the part#'s ? I have a water pump pulley that's for 396 smog motor. Of course if I sold it to you, the one on my motor would brake in half tomorrow.
Title: Re: Pulley's
Post by: Camaro3 on August 27, 2006, 08:37:02 AM
That would be my luck to. Let me look around and check out these web sites and I had a friend look at a show yesterday and think we he may have found the pulley. He paid 5.00 for it.
