Camaro Research Group Discussion => Originality => Topic started by: Rohebo on May 20, 2013, 05:30:42 PM
Title: Where to look for build sheet on very original 67
Post by: Rohebo on May 20, 2013, 05:30:42 PM
1st post here.
I've read that build sheets in '67 Norwood cars is rare.  But if I was going to take the time to start pulling things apart on my car where would be the best place(s) to start?
It's a 327 convertible with original seats/covers, door panels and carpet.
Thanks in advance.
Title: Re: Where to look for build sheet on very original 67
Post by: lakeholme on May 20, 2013, 07:50:39 PM
Look under the back seat. You'll pull it anyway.
Post by: Rohebo on May 20, 2013, 10:34:06 PM
I should have noted that I've already had the back seat out (top and bottom) as well as both rear side panels (detailing...).
Post by: JohnZ on May 21, 2013, 11:50:04 AM
Quote from: lakeholme on May 20, 2013, 07:50:39 PM
Not a good location - the rear seat (and rear carpet) was installed by Fisher Body, long before the Chevy broadcast sheet even existed.
Post by: Mike S on May 21, 2013, 12:05:03 PM
 I've heard the drivers side gas tank top was another area to look at.
Post by: Rohebo on May 21, 2013, 01:29:47 PM
Not sure if it matters much, but this is a very late build '67 (July - can't remember the week).
So it sounds like dropping the tank might be worth a shot.
I've blindly "felt" under the front seats and didn't feel anything.
Is there a chance it could be behind the front-seat back?
Post by: JohnZ on May 22, 2013, 10:29:20 AM
Quote from: Rohebo on May 21, 2013, 01:29:47 PM
You won't find one on the gas tank on a Norwood car, or in the front seat back (the front seats were installed by Fisher Body too).
Post by: 69Z28-RS on May 22, 2013, 01:45:24 PM
John,
that leaves the question:
'Is there ANYWHERE on a Norwood car where there *might* be an accidentallly tucked build sheet??"
Post by: Rohebo on May 22, 2013, 02:42:28 PM
Exactly!  Perhaps I need to phrase this differently.
In what locations has anyone (or you know of someone else) found the build sheet on a Norwood built car?
I'm particularly interested in a '67, but at this point I'll take whatever I can get!
This isn't a big deal for my car as it's not a high-option car (and the RS shows on the trim tag).
And I have the protect-o-plate that lists the door edge guards code!
Thanks again in advance for any info.
Post by: 69Z28-RS on May 22, 2013, 04:57:15 PM
Your protecto plate lists 'door edge guards'???  that surprises me.... but I don't know much about '67 PTP...
Post by: Rohebo on May 23, 2013, 01:32:38 PM
Gary,
Those door edge guards are about all I got!
Here's a link to where the '67-'69 protecto codes reside on CRG (all the way near the bottom):
http://www.camaros.org/numbers.shtml
Post by: JohnZ on May 24, 2013, 09:42:51 AM
Quote from: 69Z28-RS on May 22, 2013, 01:45:24 PM
John,
No. The statistical probability of finding a broadcast sheet on a Norwood car is zero.
Post by: 69Z28-RS on May 24, 2013, 09:46:03 AM
thanks John.      so there is no need to wish/hope.. or look.  :)
Post by: sbmiano on July 02, 2013, 10:50:05 AM
my 69 z28 built 04D Van Nuys.  When it was restored they found build sheet taped to gas tank
Post by: rsr on July 04, 2013, 07:37:53 PM
Are you saying no bodybroad cast sheets have been found in Norwood cars?
Post by: tmodel66 on July 05, 2013, 08:38:21 AM
Quote from: rsr on July 04, 2013, 07:37:53 PM
Yep
Post by: bc69 on May 07, 2014, 08:51:31 PM
Have a friend that bought his 67 new. He showed me the broadcast sheet for it and said it was in the glove box.
It is a Norwood car.
