Were window washers standard on all 69's as mine has no signs of ever having any.
I hope your talking about the wind shield washer and yes they were on every car as far as I know.
Yes windshield washers! Not the guy who came with the car who cleaned your windows! LOL
I have no signs of ever having a canister, hose holes metal lines zipo. I will be removing the hood and vent kowl soon to redo the strips correctly so I will look internally and ck. Thanks. Jim
Back in the day....a windshield washer was standard regardless if you wanted one or not when exiting the NYC side of the Midtown Tunnel
and usually with a dirty squeegee. If you paid then you got a clean windshield and if not then you were left with dirty water on the glass :D
Some left a lot more than dirty water on you windows
I realized why I theres no sign if window washers. Its because someone replaced the inner fender liners and theres no mount holes. Plus they removed all hoses and squirters.
I noticed in the close up pics of the firewall paint that the metal squirters look like theres a black calk or putty around the hole they through is that correct?
Yes the little valley that the squirters lay in has a bit of dum-dum in it to seal around the squirters.
