Camaro Research Group Discussion => Decoding/Numbers => Topic started by: jsg1010z on January 11, 2013, 04:10:13 PM
Title: 69 camaro big block manual flywheel
Post by: jsg1010z on January 11, 2013, 04:10:13 PM
I have seen online references to xxx733 and xxx458N  for the correct flywheel numbers.  I searched the CRG database but could not confirm.  Thanks for your help. :)
Title: Re: 69 camaro big block manual flywheel
Post by: 1968RSZ28 on January 11, 2013, 04:38:14 PM
Quote from: jsg1010z on January 11, 2013, 04:10:13 PM
The correct casting number is 3789733.
Post by: bertfam on January 11, 2013, 04:38:30 PM
As per Jerry's "The Definitive 1969 Camaro Z28-SS396 Fact Book":
QuoteAll manual transmission big blocks (except the ZL1) were equipped with an 11.00 inch cast iron flywheel (casting number, 3789733).
Post by: jsg1010z on January 11, 2013, 05:05:37 PM
Thank you!
Post by: JohnZ on January 12, 2013, 10:43:52 AM
That would be more correctly described as a 14" 168-tooth flywheel drilled for an 11" clutch.
