Camaro Research Group Discussion => Originality => Topic started by: pracing on December 19, 2012, 02:32:07 AM
Title: 67 350 metal vacum line correct
Post by: pracing on December 19, 2012, 02:32:07 AM
Going back to the organal carb on my 67 RS/SS 350/295 Hp & looking for the correct vacum line routing from dist to carb. It had a holley carb & it not sure if the metal line is correct
Title: Re: 67 350 metal vacum line correct
Post by: bertfam on December 19, 2012, 09:54:39 AM
The 67 L48 engine (350/295) used a Rochester Q-Jet, so you need to get THIS ONE (http://www.rickscamaros.com/camaro-vacuum-advance-tube-set-small-block-for-cars-with-cast-iron-intake-manifold-1967-1969.html).
Post by: z28z11 on December 20, 2012, 07:32:19 PM
Hey pracing -
I've got one of these if you need an original - be glad to send it to you if you'll pay the freight. I'll try to dig it out of the frozen garage tonight and get a pic if you want -
Post by: 68camaroz28 on December 20, 2012, 07:54:26 PM
Maybe its correct for the q-jet but for our Holley set up the kits have the wrong small piece to the carb. Our orig. vs. a piece of the stripped vac. hose.
Our original
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_7763.jpg)
Original to left vs. kits piece.
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_7761.jpg)
(http://i192.photobucket.com/albums/z117/1-2-b-67L89/68%20Camaro%20Z28/100_7759.jpg)
Post by: bertfam on December 21, 2012, 11:09:14 AM
I've been told that the DOC REBUILD (http://www.docrebuild.com/dr-r-web/3750338.HTML) vacuum hoses are "correct". I haven't checked it out myself, but the same hose was used throughout GM for a number of years, not just Corvette and Camaro.
By the way, there are a couple of good pictures of the Q-Jet tube and hoses in THIS (http://www.camaros.org/forum/index.php?topic=2071.0) thread. This engine is a 68 L30 (327/275) but the setup is the same as the 67 L48 engine (350/295).
