Hi does anyone have a picture of spring location. i dont want to clamp on headers is there another spot for the spring.. pictures would be great thanks ???
I think mine goes up to the frame motor mount. Might have a longer spring than stock or one added to it. I will look
Swap the spring and rod positions and it will work much better with the headers.
I put a small piece of metal with a hole drilled into it on the motor mount through bolt.
