Camaro Research Group Discussion => General Discussion => Topic started by: tjs69 on October 02, 2012, 04:06:48 PM
Title: Big Block engine offset
Post by: tjs69 on October 02, 2012, 04:06:48 PM
Hi guy's !
I noticed in your engine/frame mount that you mentioned that Big Blocks were moved to the passenger side by 1".
This is actually only 1/2".  If you measure from the carburetor stud to each fender you should get approximately 24 3/4" driver's side and 25 3/4" on the passenger side.  The difference in your measurements is 1", but the engine is only moved off of center 1/2". (1/2" offset)
Example: Distance from center to each fender = approx. 25 1/4 "  Add 1/2" to driver's side =25 3/4". Subtract 1/2" from passenger side = 24 3/4"
This 1/2" offset matches the transmission crossmembers 1/2" offset .  The transmission crossmember also moves the transmission mount 3/4" forward of the small blocks location.
The BB engine frame mounts also move the engine forward that 3/4", also.
Thanks Guys !
Tom
Title: Re: Big Block engine offset
Post by: lcmc on October 03, 2012, 07:16:27 PM
If you read it the key word is "offset" not moved.
Post by: camaro jock on October 06, 2012, 11:59:13 AM
Thanks for the math lesson I did not know it was so complicated. :D
