Author Topic: Power STeering Power Booster hose???  (Read 12901 times)
greg1ontheedge
« on: July 24, 2006, 03:12:13 PM »
I'm installing an Edelbrock Crossram manifold on the 350 in my '68 Camaro.  The power steering power booster has a 1/2 or 5/8 hose that runs to the intake manifold.  There's no provision for it on the Crossram manifold.  What the heck do I do with it???  Thanks much.............
BlackoutSteve
Re: Power STeering Power Booster hose???
« Reply #1 on: August 20, 2006, 06:00:08 AM »
Power brake booster right?
The hose is a 3/8" I.D., and you'll need to install a fitting to your new manifold so you will still have power brakes.
This is easiest done with the manifold off the engine, but not impossible to do on the engine if you take precautions not to get aluminum down the ports.
Your local auto supply store should have the fittings in stock and your hardware, the correct thread taps and right size drill bits.
