Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
'69 horn wiring
« previous
next »
Print
Pages: [
1
Author
Topic: '69 horn wiring (Read 6429 times)
Springer Tom
Member
'69 horn wiring
on:
September 03, 2012, 01:27:40 AM »
Could someone please explain how the 2 wires from the horn buttons on a '69 2 spoke wheel connect to the column? I have a spring and a metal button also.....this car is making me dumb
Tweet
Logged
BlackoutSteve
Member
Re: '69 horn wiring
Reply #1 on:
September 03, 2012, 11:37:27 AM »
Not explained in UPC12-C1 & C5?
Logged
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Springer Tom
Member
Re: '69 horn wiring
Reply #2 on:
September 03, 2012, 12:32:20 PM »
Yeah Steve, I got all that, but the spring and contact don't fit in the sleeve when you put the little grommet with the wires in it....for now I left the contact pin out, I 'm wondering if the contact is too long....
Logged
Everett#2390
Member
^Bess
Re: '69 horn wiring
Reply #3 on:
September 03, 2012, 01:31:01 PM »
Is the spring too big to fit into the hole?
I would imagine the contact fits into the hole above the spring and twist & lock into place?
Logged
A flashlight is a case for dead batteries.
tmodel66
Hero Member
Re: '69 horn wiring
Reply #4 on:
September 03, 2012, 02:21:57 PM »
Hey Tom are you using a repop horn button and turn signal switch? If you are they are wrong and will not work.
Logged
Daniel
'69 SS 350/4 speed Fathom Green--POP
Springer Tom
Member
Re: '69 horn wiring
Reply #5 on:
September 03, 2012, 02:37:12 PM »
Well that explains it, I should be used to this crap by now >:(who has the correct ones?
Logged
tmodel66
Hero Member
Re: '69 horn wiring
Reply #6 on:
September 03, 2012, 04:43:24 PM »
I took 2 and made 1. I used the bottom half of my new one and the upper half of my old one. I couldn't find a plug and play switch. Good luck with that. The long tube that the horn wire plugs into is wrong and doesn't have the locking notch and is too tall for the wheel to set on. I used this part off my old one.
Logged
Daniel
Print
Pages: [
1
« previous
next »
Maintenance
'69 horn wiring
