Author Topic: 6 cylinder trim tags  (Read 4373 times)
DT
« on: August 14, 2012, 01:51:37 AM »
Did the trim tags on a 69 6 cylinder car have 12437 or 12337 ???
Donny
tmodel66
Re: 6 cylinder trim tags
« Reply #1 on: August 14, 2012, 02:15:48 AM »
The trim tag was not connected to 6 or 8 cylinder.  Only VIN reflected whether it was 6 or 8. The "4"  in 12437 was fixed at 4 for '69. The last two numbers told you if it was coupe or convertible. Read about it here
http://www.camaros.org/numbers.shtml#VINvsStyle
DT
« Reply #2 on: August 14, 2012, 09:41:12 AM »
Thanks for the info.  I have a Camaro book that stated the trim tag should read 12337 for a 6 cylinder.  I thought that was incorrect.  problem solved.
Donny
