Author Topic: Strange Block Casting Number  (Read 4152 times)
chilipepper13
« on: July 22, 2012, 02:24:59 PM »
Hi there
Finally assembled all the numbers of my engine today while taking pictures of everything. Something about the engine block casting got me puzzled. My car is a very early 1969 SS/RS 350 (engine build date on the pad stamp indicates Sept 25) and it has the block casting number 3927185 GM 5 T. According to an article on CRG a 1969 350ci block should start with 393 though  ???
Any help would be greatly appreciated! Thanks,
Eddy C.
1969 SS/RS 350 Convertible
Re: Strange Block Casting Number
« Reply #1 on: July 22, 2012, 02:33:05 PM »
3927184 isn't the block casting number. That's the intake manifold casting number.
Boston14
« Reply #2 on: July 22, 2012, 02:33:44 PM »
The picture you show is the casting number of the Tonawanda cast intake manifold, which is correct for Tonawanda built 350 4 barrel engines.  The block casting number is on the block surface between the bellhousing and intake manifold (behind your coil and distributor).
boston14
Gramps69Z
  • 69 X33 D80
« Reply #3 on: July 22, 2012, 03:39:44 PM »
Captain John Wykoff
chilipepper13
« Reply #4 on: July 22, 2012, 03:55:35 PM »
Duh... :-[
Thanks for clarification!
Eddy C.
