CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
June 18, 2013, 09:11:56 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
83161 Posts in 10593 Topics by 4405 Members
Latest Member: Lancejames22
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Originality
| | |-+  Speedo cable Clips
« previous next »
Pages: [1] 2 3  All Print
Author Topic: Speedo cable Clips  (Read 3366 times)
Hero Member
View Profile Email
« on: July 09, 2012, 10:18:15 PM »
Both the 68 & 69 AIM call out 3 speedo clips. 68 AIM UPC M20 A6
Both the 68 & 69 AIM under UPC 0, A8.5 & A9 respectively, call out two holes to be drilled.
Our 68 did not have 3 speedo clips and two other 69's I'm aware of only have two.
Just wondering if two clips is a common sight among NOR Camaro's.
The other thing found today on a NOR May built Z/28 was a difference in the two clips.
We took the one out near the front of the trans tunnel and it is a totally different design
from the one on the cowl even though the AIM calls out 377324 for all three.
I know of one 68 that only had one clip! What do you have on your 4-speed cars?
Here are the two clips!
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
BlackoutSteve
Member
138139883
View Profile Email
« Reply #1 on: July 10, 2012, 06:15:29 AM »
To me, they look like they are the same clip except the lower one pictured looks like someone has folded it over backwards and made a real meal out of it..
http://www.heartbeatcitycamaro.com/store/product/17753/Camaro-Speedometer-cable-retainer-67-68-69/
Logged
Stingr69
Member
View Profile Email
« Reply #2 on: July 10, 2012, 04:09:56 PM »
I have a 10A '68 built Norwood 69 Camaro that does not have the speedo clips on the underside of the floor and I have looked pretty hard for evidence. Original Muncie car.
-Mark.
Logged
Hero Member
View Profile Email
« Reply #3 on: July 10, 2012, 05:18:26 PM »
Steve, the repro clips are not correct so original Muncie 4-speed clips can be somewhat of a challenge to find. The clip in question we took out and it was folded differently and sure seemed like a different type clip with the same type fastener (that goes in hole). We have no reason to believe this clip was removed, reworked and put back in. The fold for holding the cable is opposite.
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
montgomg
Member
View Profile
« Reply #4 on: July 10, 2012, 05:22:38 PM »
My 69 Z28 (Norwood car) only has two speedo clips. The one on the firewall and the one nearest the tranny. There is a dimple in the lower firewall/tunnel area where the other speedo clip hole should have been drilled but wasn't.
Logged
BlackoutSteve
Member
138139883
View Profile Email
« Reply #5 on: July 10, 2012, 06:01:48 PM »
It may never have been removed, but looking at just those two pictures, there appears to be signs of folds and creases on it that are remarkably similar to the first "normal" clip shown.
There is no doubt, going by it's poor condition and contour, that someone at some time has had a go at it.. I have never seen speedo clips bent backwards like that and I wonder why would GM have made two different styles of clip to do the same job in roughly the same place on the same car?
I could be wrong. Smiley
Logged
Hero Member
View Profile Email
« Reply #6 on: July 10, 2012, 06:43:41 PM »
Could be correct Steve but the reason for me asking question similar to how many clips does one's car have. AIM calls out three but is that the norm? How many clips do you have?
So Mark your 68 only has (one) the cowl clip?
Thanks montgomg! Intersting for sure.....
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
flyingskibiker
Member
View Profile
« Reply #7 on: July 10, 2012, 07:47:35 PM »
My 11C 68 NOR M21 has 3 clips.  Two originals were still in the car: tunnel/rear and pass. side lower firewall (smashed!).
Logged
Hero Member
View Profile
« Reply #8 on: July 10, 2012, 07:49:03 PM »
 I just checked and found my 67 NOR 05B w/4 speed Muncie has only 2 holes drilled with 2 clips. One at the firewall (like your picture) and the other near the tranny.
Logged
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Hero Member
View Profile Email
« Reply #9 on: July 11, 2012, 01:44:58 PM »
My LOS 68D has all 3.
Logged
Hero Member
View Profile Email
« Reply #10 on: July 11, 2012, 11:20:28 PM »
Checked a friends NOR 68 07D survivor and it had two, one at cowl and one in tunnel.
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
Paul68RS/Z28
Member
View Profile
« Reply #11 on: July 12, 2012, 07:23:33 PM »
Chick,
My 04D Z28, NOR, Has the one at the front of the trans and the one back further into the tunnel. The one at the front is just back from were the firewall and tunnel meet, pass side for both.
Logged
1968 Z28
Member
View Profile Email
« Reply #12 on: July 12, 2012, 07:55:59 PM »
Hi Chick....two, one on firewall/tunnel and the other in front of the crossmember in tunnel, both on passenger side.  No clips around the firewall hole.  Check signature for vehicle.
Logged
Jerry G.
Z28-1968-07C-Norwood
2 Owner, 38,000 miles
CRG Member
View Profile Email
« Reply #13 on: July 13, 2012, 11:11:32 AM »
My NOR 02D '69 Z/28 has all three clips, and all three are the same clip.
Logged
Hero Member
View Profile Email
« Reply #14 on: July 13, 2012, 12:04:21 PM »
05D 68 Z  I mustn't have had my glasses on for that one!
Logged
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.094 seconds with 17 queries.
