Author Topic: power steering clamp  (Read 3913 times)
sebastien
« on: May 31, 2012, 02:58:10 PM »
Where is the correct location for the clamp that holds on one of the power steering hoses ? (which bolt of the steering box cover) and which hose (return)? I think p/n is 9420534
1968 small block.
thank you
Sebastien 68  327 rag top
Re: power steering clamp
« Reply #1 on: May 31, 2012, 03:47:45 PM »
If you mean THIS ONE, it bolts to the front passenger side cover bolt and holds the pressure hose.
sebastien
« Reply #2 on: June 01, 2012, 02:00:42 PM »
thanks Ed
sebastien
JKZ27
« Reply #3 on: June 02, 2012, 01:33:00 AM »
Was this clamp on all 67-69 cars with P/S? Small block and big block?
John
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #4 on: June 02, 2012, 01:50:06 AM »
Yes, 67-69, but only on V8 engines. L6's didn't use it.
By the way, that P/N (9420534) isn't the clamp I linked to. 9420534 is the clamp to attach the rubber return hose to the metal tubes that are screwed into the steering gear and the pump. The clamp I linked above has no part number because it was part of the steering gear assembly.
