CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
June 19, 2013, 05:56:29 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
83196 Posts in 10595 Topics by 4407 Members
Latest Member: georgeshaw
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  General Discussion
| | |-+  1969 console gauges / clock and more Questions
« previous next »
Pages: [1] Print
Author Topic: 1969 console gauges / clock and more Questions  (Read 304 times)
ban617
Member
View Profile
« on: May 28, 2012, 02:49:50 PM »
Ok so what I have found says you recieved the clock in the dash as part of the console gauge package correct u17 ? Also how much time from assembly date on the engine to build date of the car? (The only real way to tell is by vin on the bell housing flange) lastly for a Z/28 to be a RS as well could only be an X33? Thanks Rob
Logged
CRG Member
View Profile Email
« Reply #1 on: May 28, 2012, 03:08:07 PM »
Yes U17 included a clock. You will see plenty of '69s with gauges but no clock; it indicates the gauges were retrofitted.
With all of the engines available for '69 there is no time span that can be reliably applied to all. For example a bud had an 06A L78 Camaro with a late April engine. 06A Z/28s typically have much later engine dates.
A Z/28-RS built at Norwood when X codes entered production would be X33. However X33 does not indicate RS; only style trim on a Z/28. Van Nuys built Camaros do not use X codes.
Logged
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.076 seconds with 17 queries.
