May 23, 2013, 05:07:28 PM
Search:     Advanced search
82185 Posts in 10499 Topics by 4350 Members
Latest Member: clydehale25
+  CRG Discussion Forum
| |-+  Maintenance
| | |-+  Plug gap for Pertronix
« previous next »
Pages: [1] Print
Author Topic: Plug gap for Pertronix  (Read 712 times)
68Zproject
Hero Member
View Profile Email
« on: May 13, 2012, 04:34:27 PM »
Just wondered if the plug gap should be wider when running the pertronix or left at standard.  Thx.
Logged
68Z28
mickeystoys69RSSS
Member
View Profile
« Reply #1 on: May 13, 2012, 05:44:51 PM »
If you are running a higher output coil then the gap would be larger. For example the plug gap for my stock 396/350 hp stock coil and dist. is 0.35 but for the later model HEI' with higher output they were 0.45 gap. The higher energy you have going to the plug to arc across the larger gap then the more spark you will have exposed to the compressed A/F mix. I am not familiar with that particular brand and what the plug gaps should be set at exact though.
Logged
srode
Member
View Profile Email
« Reply #2 on: May 13, 2012, 06:18:22 PM »
I am running .040" with no issues using the MSD blaster coil (painted satin black of course).  I have heard you can run .045 with these hotter coils but chose to be conservative.
Logged
Steve - 02D Z11 and a Plain Jane hardtop
CRG Member
View Profile Email
« Reply #3 on: May 14, 2012, 10:02:22 AM »
The Pertronix conversion module simply replaces an electromechanical switch (the points) with an electronic switch; it has no effect on spark energy. Plug gap remains stock (.035").
Logged
68Zproject
Hero Member
View Profile Email
« Reply #4 on: May 14, 2012, 06:23:49 PM »
Well, I did the right thing without knowing.  I put it together before I got the reply and put them at .035.  I got lucky this time.  Thanks.
Logged
68Z28
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.082 seconds with 17 queries.
