Author Topic: 67 camaro carb ?  (Read 4640 times)
kid56
67 camaro carb ?
« on: May 05, 2012, 08:42:53 PM »
Hello guys , I have a ? about the carburetor I need for my 67 ss/rs 396(4N) 4 speed no A.I.R.,  according to the CRG chart, it is a rochester #7027201 ER  (early)
and # 7027211 LD (late) My car was built in Los angles O2C not sure which one I need or the date they changed them
thanks Mike B
Re: 67 camaro carb ?
« Reply #1 on: May 06, 2012, 04:51:06 PM »
 I have seen the 7027211 carbs (rare to find, BTW) with dates as early as Feb 67. Your period may be at that transition period (just a guess) between the old and newer one. I'm sure GM must have depleted inventory before using the newer ones. The differences are the needle and seat design.
   Also, the linkage may be different between the 2 models. The earlier one use the larger sleeves at the carb throttle side and the 7027211 doesn't use a sleeve at the car throttle. The after market throttle linkage for the 67 BB doesn't fit the newer 211 carb correctly because the throttle side needs the large sleeves to properly fit. My 67 BB car has the 211 carb and also the 2 piece linkage that came with it when I bought the car over 30 years ago. My 67 LOS car that uses a different carb number all together also uses the 2 piece linkage.
BTW, a LOS car without AIR? I thought that was mandatory in 67 for California.
« Reply #2 on: May 06, 2012, 06:01:49 PM »
Apparently not a Ca. delivery.
MO
« Reply #3 on: May 06, 2012, 07:18:16 PM »
In 1967 the LOS plant built cars with and without smog systems. Cars delivered in CA (and presumably special ordered with the equipment for out of state sale) got it; normal out of state delivery cars did not.
kid56
« Reply #4 on: May 06, 2012, 09:43:15 PM »
it was sold new in southern idaho
mike B
« Reply #5 on: May 08, 2012, 05:11:37 PM »
I know of a mid-March car and it has a late design carb.
« Reply #6 on: May 11, 2012, 05:48:53 AM »
And please don't double post - aka post the question is two different forums. I deleted the other one.
