Author Topic: ss 350 4spd options  (Read 18647 times)
mossyoak1964
ss 350 4spd options
« on: April 15, 2012, 12:51:09 AM »
I am new to this site and have some q's about 4spd options for the 1967 ss 350. My car is all number matching with protect-o-plate. The Rear end code that matches the protect-o-plate is PL0919G
PL=4-speed close ratio 3.55:1 rear gear. I thought the close ratio Muncies where installed in z's and big blocks? This car is a L48 295hp 350 Cal. built with speed warning indicator and heater delete. Has anyone documented a m-21 in a SS-350? Thanks
Kevin,
1967 L 48 SS 350 4spd
Marina Blue/White
tmodel66
Re: ss 350 4spd options
« Reply #1 on: April 15, 2012, 12:57:16 AM »
PL has nothing to do with the transmission. That is the rear axle code only. What does your cowl tag show for the transmission code?
Daniel
IZRSSS
  • Guest
« Reply #2 on: April 15, 2012, 01:35:05 AM »
"I am new to this site and have some q's about 4spd options for the 1967 ss 350. My car is all number matching with protect-o-plate. The Rear end code that matches the protect-o-plate is PL0919G
Daniel is correct. PL is only used to identify the axle type. In your case a 3.55:1, 12 bolt, Non Posi. Built Sept. 19, 1st Shift".
"I thought the close ratio Muncies where installed in z's and big blocks"?
That's correct. The M21 was for Z28's, L34's & L78's.
Can you post pics of the POP, the cowl, the Vin #, and the engine pad? If you have trouble posting pics send them to my email address & I'll try to post them for you.
BTW...welcome!
x77-69z28
« Reply #3 on: April 15, 2012, 03:07:53 AM »
THE l48'S CAME WITH AN M-20
mossyoak1964
« Reply #4 on: April 15, 2012, 03:29:46 AM »
The Protect-O-Plate has P7R04 listed for the transmission. I will try to take some pics of the POP and post. I got the information regarding the PL being a M-21 from chevrolet by the numbers. All numbers that I have followed up with have checked out. The RPM change between gears when I drive indicates close ratio. Thanks
Vin: 124377L112XXX
Deluxe Parchment
Marina Blue with white stripe
Block V1025MT 3892657
Cowl tag
Option 2 4spd, console, rear antenna, rear speaker
Option 3 z23/z21
Option 4 SS 350
Option 5 Deluxe seat belts
Kevin,
Marina Blue/White
mossyoak1964
« Reply #5 on: April 15, 2012, 03:44:00 AM »
Cowl tag:
10D                                                      X119
67-12637  Los     4347
797-Z             F-F
 W  SLGSR        3SDK
 4P  5Y
Protect-O-Plate:
K         FF                      R
V1025MT     PL0919G     K
P7R04           4   4
Kevin,
Marina Blue/White
« Reply #6 on: April 15, 2012, 04:18:07 AM »
No idea why CBTN's has that 'close ratio' note for that axle. It's incorrect.
You car has traveled some in the past few years - CA, KY, OH, MO.
IZRSSS
  • Guest
« Reply #7 on: April 15, 2012, 04:36:12 AM »
Looks like its already in the CRG data base but here you go Kevin;
« Last Edit: April 15, 2012, 05:20:54 AM by IZRSSS »
IZRSSS
  • Guest
« Reply #8 on: April 15, 2012, 04:37:35 AM »
mossyoak1964
« Reply #9 on: April 15, 2012, 05:04:54 AM »
Engine & Tran  ??? ??? ???  Sure hope I'm wrong! Need a pic of the engine pad to make sure. Maybe it's in the data base. But the number you gave doesn't match. And of course, neither does the M21.
Thanks for posting the pics!
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #10 on: April 15, 2012, 05:24:29 AM »
Your welcome Kevin.
BTW...don't put any meat into that quote of mine. I got confused with the mention of the M21 for an L48. I should have paid closer attention to what Daniel wrote! I missed your PL=...
mossyoak1964
« Reply #11 on: April 15, 2012, 05:48:58 AM »
Your welcome Kevin.
Marty,
I sent you a pic. of the engine pad. These #'s seem to match the POP, but I realize that people have been building frauds and claiming #'s match for years. I have verified all the numbers on the car and they match the POP to Vin #. Hopefully its the real deal. Thanks
Kevin,
Marina Blue/White
mossyoak1964
« Reply #12 on: April 15, 2012, 06:03:36 AM »
Note for reference: CBTN's 1965-69 with red 68 396 conv. on cover page 309 under 1967 camaro rear axle codes
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #13 on: April 15, 2012, 02:06:37 PM »
Kevin - So far everything checks out. The pad looks great, including the cowl. See if you can get me a straight on shot of your POP and I'll brake it down for you as well. A pic of the partial vin on the tran would be nice also.
IZRSSS
  • Guest
« Reply #14 on: April 15, 2012, 02:08:17 PM »
BTW, gorgeous car!
mossyoak1964
« Reply #15 on: April 15, 2012, 09:42:42 PM »
The only thing that I have decoded differant is under the Option 2 L=M20/M21 4spd. This car currently doesnt have fold down back seat.
Kevin,
Marina Blue/White
mossyoak1964
« Reply #16 on: April 15, 2012, 09:49:55 PM »
Is there any way other than pulling the cover on the trans. to determine if this is a M20 or M21? Everything I see has not indicated that this is not a M21.
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #17 on: April 15, 2012, 10:24:56 PM »
I haven’t had anything stronger than water the last couple days, really; hiccup, hiccup, hiccup. :-\
3x a charm ???
(1) W-Tinted (windshield only)
(2) L- 4 speed floor shift {“M20/M21”}
     G- Console front compartment
     S- Antenna manual-RR
     R- Speaker rear
(3) S- Interior décor grp
     D- Lamp courtesy (coupe-under dash only)
     K- Ext moldg grp
(4) P- Radius rod
(5) Y- Belts deluxe
IZRSSS
  • Guest
« Reply #18 on: April 15, 2012, 10:29:01 PM »
Follow the RPO on the left hand column until you see M21 and check the requirements (off to the right). There is no way a M21 would have come from the factory in a L48. If it did it would show up here; http://www.camaros.org/pdf/options.pdf
Do you have any numbers off the side of the trans? This should tell us exactly what you have. You can find the "Maincase Casting Numbers" here; http://www.camaros.org/trans.shtml#4speed
mossyoak1964
« Reply #19 on: April 15, 2012, 10:49:45 PM »
Marty,
I have sent you the trans, and POP. I had a hell of a time locating the partial Vin # on the trans. It was located on top back by the tail housing. Thanks again!!
Kevin,
Marina Blue/White
mossyoak1964
« Reply #20 on: April 15, 2012, 10:56:22 PM »
Here is the #'s on the case: 3885010  3088336  3857584 tail housing.
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #21 on: April 15, 2012, 11:24:42 PM »
Look at the 2nd one down under Muncie; It's yours...3885010 {M20}...Key on this link; http://www.camaros.org/trans.shtml#4speed
I did get your other pics. I'll have them posted in a few.
« Reply #22 on: April 15, 2012, 11:32:02 PM »
Yes - If the rpm drop from 1-2, 2-3, and 3-4 shifts is pretty much the same, it's an M21; if the rpm drop at 3-4 is significantly more than from 1-2 or 2-3, it's an M20.
IZRSSS
  • Guest
« Reply #23 on: April 16, 2012, 12:13:41 AM »
Here are three of your four other pics. I'll work on the POP in the next day or so. Right now I have a date with my son, easy chair, and the Yankees and Angels. We're headed up to Cal next month to see them live so this is kind of a precursor. ;)
IZRSSS
  • Guest
« Reply #24 on: April 16, 2012, 12:14:11 AM »
mopar346
« Reply #25 on: April 16, 2012, 12:55:59 AM »
Could it be a M20 case with M21 guts or aftermarket gear set? Not up on Muncies as far as what will interchange, I know you cant mix and watch but could you change all the innards?
IZRSSS
  • Guest
« Reply #26 on: April 16, 2012, 03:29:16 PM »
Kevin- Here's your POP (could not find RPO U15- Speed Warning Device). I don't think I have ever seen a closer car and engine build date; Car-10D, Engine-10/25.
Your "Guards, door-edge" is RPO B93
BTW, If you get some time and figure out this posting pics thing, would you mind posting your L48 on this thread? http://www.camaros.org/forum/index.php?topic=8314.0. This link might help you with posting pics; http://www.camaros.org/forum/index.php?topic=7215.0. Or, this one; http://www.camaros.org/forum/index.php?topic=4896.0
« Last Edit: April 16, 2012, 04:09:41 PM by IZRSSS »
tmodel66
« Reply #27 on: April 16, 2012, 04:33:56 PM »
I always thought 4P was the code for SS350 not just a radius rod. L30/M20 also got the 4P but we know in this case it's not an L30 car so the 4P code would indicate SS350.
Daniel
crobjones2
« Reply #28 on: April 16, 2012, 08:43:34 PM »
something doesn't add up - correct me if I'm wrong
a 350/ 295 would have a 4BBL carb - but POP indicates a 2BBL
Chris
69 SS 350
« Reply #29 on: April 16, 2012, 08:53:24 PM »
Marty just made a typo.  It should be a R instead of a B for the carburetor code as Kevin has noted in reply #5 above.  R would make it a Quadra-Jet.
IZRSSS
  • Guest
« Reply #30 on: April 16, 2012, 09:32:41 PM »
Dan- I got that info here under Fisher Body Codes. Did I interpret it wrong? It's for 67's only; http://www.camaros.org/numbers.shtml#67Codes
Thanks for being diplomatic about it Paul, I screwed up! Must be that mirror image thing. :)
mossyoak1964
« Reply #31 on: April 16, 2012, 10:21:47 PM »
Ya, the carb # is a 7037203 k6 DY Rochester.
Kevin,
Marina Blue/White
mossyoak1964
« Reply #32 on: April 16, 2012, 10:31:20 PM »
I found a tag on the drivers side of the transmission on one of the side plate bolts that looks like an old rear-end tag. 3870357
I can't seem to find any reference to this tag #. Can someone help identify? Thanks
Kevin,
Marina Blue/White
mossyoak1964
« Reply #33 on: April 16, 2012, 10:44:04 PM »
Can someone help explain the second # 4 on the POP. I thought this stood for heater delete. One other option that was identified earlier is the radius rod for the rear axle. This rear end doesn't show signs of a bracket every being welded to the drivers side of axle. ????Thanks
Kevin,
Marina Blue/White
tmodel66
« Reply #34 on: April 16, 2012, 11:44:15 PM »
It's the transmission ID tag. It's the correct number for a Muncie M20.
Daniel
« Reply #35 on: April 16, 2012, 11:45:41 PM »
Quote
3870357 is the final assembly part number for the M20 transmission used on the 1967 L48 and L35 engines.
Quote
C48 is indicated as position e, number 4 in the POP DECODE SECTION. Your POP shows position c and f (both number 4), so you have U63/U80 (Am radio with rear speaker) and B93 (door edge guards).
Your car's too early for the radius rod. More info HERE.
mossyoak1964
« Reply #36 on: April 17, 2012, 12:07:42 AM »
TR
Quote
Quote
Ed,
I guess that explains what trans this car has. Thanks for info!
Kevin,
Marina Blue/White
mossyoak1964
« Reply #37 on: April 17, 2012, 12:12:57 AM »
One last ???? I didn't see any indication of a speed warning indicator listed with the option either on the POP or the cowl tag, but this car has a fully functional one that apears to be original. This car hasn't had one suprise with any of the other options an I feel that it is original. Thanks for everyones help!!!!
Kevin,
Marina Blue/White
mossyoak1964
« Reply #38 on: April 17, 2012, 12:18:23 AM »
Marty, just figured it out and posted some pics on L 48 WDOAL. Thanks for you help.
Kevin,
Marina Blue/White
« Reply #39 on: April 17, 2012, 12:28:11 AM »
Quote
One last ? I didn't see any indication of a speed warning indicator listed with the option either on the POP or the cowl tag, but this car has a fully functional one that apears to be original.
U15 wasn't listed on the POP or the trim tag.
IZRSSS
  • Guest
« Reply #40 on: April 17, 2012, 12:32:55 AM »
That's correct. I too have the POP and it isn't on there. I took these pics of my original U15 for another member a couple of days ago. Does yours look similar to it? All of this will be in your '67 AIM (Assembly Instruction Manual).
IZRSSS
  • Guest
« Reply #41 on: April 17, 2012, 12:35:51 AM »
U15 Cont'd...
IZRSSS
  • Guest
« Reply #42 on: April 17, 2012, 12:39:45 AM »
See, it isn't so bad! ;)
mossyoak1964
« Reply #43 on: April 17, 2012, 02:01:33 AM »
Ya, not bad 1 of 3698 u15 equiped cars in 67. Can anyone anwser if my car is equiped with C96  Axle; non-standard ratio (3.55:1) 1 of 6,322 . Not sure what the non-standard ratio means. I will post some pics tomorrow of the speed warning indicator. Thanks
Kevin,
Marina Blue/White
tmodel66
« Reply #44 on: April 17, 2012, 02:25:47 AM »
That's not C96 but G96. Non-standard would be something changed from the default part that was used. I don't know what the default ratio would have been but it wasn't 3.55. All cars built have default part that is used to build it. Default meaning just ordinary run of the mill cars. If something was changed it would get a different code on the build sheet so the plant workers would know what to install.
Daniel
IZRSSS
  • Guest
« Reply #45 on: April 17, 2012, 02:45:39 AM »
Kevin- Get the number off of your axle then go to this link & look at the listing under "Rear Axle Codes". The first two letters are the key; http://www.camaros.org/drivetrain.shtml#AxleCodes. It will tell you exactly what you have. Here is a pic of mine to use as reference;
Your POP says it's "PL" which is 3.55. So you are probably correct. Just verify it with what's on your car.
