Author Topic: 69 Z/28 metal vacuum line correct?  (Read 23132 times)
Re: 69 Z/28 metal vacuum line correct?
« Reply #15 on: April 03, 2012, 03:28:04 PM »
I assume both vacuum lines are available reproduction?
69pace
    • TeamCamaro - Moderator
« Reply #16 on: April 03, 2012, 08:09:20 PM »
I see the accelerator rod. What's that black linkage that's hooked to the throttle?  It looks like a kick down cable to me. That's why I thought it was an auto.
Good question, and who knows. I have only seen the mechanical kick downs mounted to the front. The thread where the pic came from was on aftermarket springs so I just assumed it was one since the factory spring is not there. The owner said it was an L48 with M21 but maybe he borrowed the pic from someone else.
« Reply #17 on: April 03, 2012, 08:56:46 PM »
It is a kickdown cable in that borrowed photo,  and you thought correctly Dan.
69pace
« Reply #18 on: April 04, 2012, 06:50:47 PM »
I wonder what the owner is using then to drive the heat-stove on the air cleaner snorkel?  The port for that is clearly capped off with the blue plug. I can't find the link again but wonder if he did a transmission conversion and left the kick-down in place. In any event to answer your question T the port to use for the vacuum advance is still the one in front on the drivers side above and to the right of the larger PCV port.
« Reply #19 on: August 14, 2012, 09:23:21 PM »
OK, now back to my original question please: Does anyone have any later production 69 Z or other wise that came originally with a rubber hose only, or did not come with the vacuum line clip? If you have a mid year 69 that came with the metal line please state the build date of your car thank you!
« Reply #20 on: August 15, 2012, 03:25:36 PM »
All '69 Z's had the metal pipe from the carb and the metal clip for it under an intake manifold bolt.
Dusk Blue Z
« Reply #21 on: August 16, 2012, 01:10:54 AM »
John, Do you have the extra port on your vacuum fitting for your "driving set up" on your car?
1969 Z/28 Legends Certified
1969 Z-10 Under Construction
1968 Z28
« Reply #22 on: August 16, 2012, 03:17:16 AM »
Well, I'm not John Z...but just four threads down from this one is a thread that has a photo of his driving setup.  I'll include the link for it.....http://www.camaros.org/forum/index.php?topic=9906.0
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #23 on: August 16, 2012, 04:53:27 PM »
For my "driving setup", I remove the short hose from the end of the steel line to the distributor and close off the end of the line with a rubber cap, and add a longer rubber hose from the vacuum advance can to the existing white plastic tee in the choke pull-off hose. That tee normally has the rubber vacuum signal hose to the diverter valve connected to it, and I just disconnect the signal hose from the tee and let the hose hang (doesn't matter, as I have a BB in that hose anyway and the A.I.R. pump is gutted).
For "correct appearance", I just remove the long rubber hose, remove the rubber cap from the end of the steel line, re-install the original short hose from the end of the steel line to the vacuum advance can, and re-connect the diverter valve signal hose to the tee in the choke pull-off hose.
The steel clip for the steel line is there, but it's hidden behind the brass fuel line Y-block in the photos.
BillOhio
    • photobucket
« Reply #24 on: August 20, 2012, 03:34:38 PM »
is there any paint on this clip on a z? One I bought has orange on it but might be off a painted manifold
1968 RS 327 4 speed
1967 Plymouth GTX Hemi, 4 speed, dana
« Reply #25 on: August 20, 2012, 07:53:40 PM »
I think they are originally black.
« Reply #26 on: August 23, 2012, 12:05:28 PM »
You may be correct and know the repops are black but thought my originals were phosphate but maybe they were a black painted phosphate clip and the paint came off??????
« Reply #27 on: August 23, 2012, 12:09:44 PM »
I looked closer at an original one that I bought, and it looks like it is phosphate with a "C" stamped in it. anyone else have an original?
1968 Z28
« Reply #28 on: August 23, 2012, 02:54:31 PM »
My original one looks like it has a natural, although gloss black, tempered steel finish, not painted.  It has an "O" stamped on the inside above the mounting hole.
« Last Edit: August 23, 2012, 03:25:21 PM by 1968 Z28 »
Jerry G.
« Reply #29 on: August 23, 2012, 11:13:27 PM »
Kinda reminds me of the old metal banding material look.
