Author Topic: exhaust manifold torque  (Read 16733 times)
68rsssrag
« on: July 05, 2006, 03:28:34 AM »
The GM spec for BB exhaust manifold to head bolts is 25 ft lbs. seems low but is there a reason?
Arno
rich69rs
  • LF7/M35/Z22/Z87
Re: exhaust manifold torque
« Reply #1 on: July 05, 2006, 04:37:50 AM »
During my engine (327) rebuild, torqued my SB exh manifold bolts to 20-30 ft-lb per spec.  Bolts are 3/8"-16, probably grade 5 material.  Torque of 20-30 ft-lb will "preload" the bolt properly.  Enough preload to keep the joint tight while not stretching the bolt to a point of permanent deformation.  Periodic recheck of the torque isn't a bad idea either.
Also, the gasket must be taken into consideration as well.  Using a high strength bolt and torquing to a higher value could impact gasket integrity.  Obviously the original specs are for original gasket, bolts, etc and might be different for performance upgrade components.
« Last Edit: July 05, 2006, 04:51:01 AM by rich69rs »
Richard Thomas
1969 RS
« Reply #2 on: July 05, 2006, 03:30:53 PM »
Quite true for most applications, but no gaskets were ever used on any Chevy V-8 exhaust manifold-to-head attachment.
68rsssrag
« Reply #3 on: July 10, 2006, 04:48:02 AM »
John
Per your earlier post I am not running gaskets.
Rich
Interestingly the Bolts are 3/8 and grade 8 so 25 footpounds isn't going to stretch these at all. I was thinking more that during operation the expansion of the manitold would possibly stress the manifold and crack the front and rear "ears" where the 1st and last bolt are located?? There must be a reason for such a low torque. L6's are 30.
Arno
« Reply #4 on: July 10, 2006, 02:49:02 PM »
L6's are 30.
Arno
On the L-6's, only the bolts that use clamps to span the ears on both manifolds are 30; the end bolts (which go through holes in the manifold ears) are 20 ft-lbs.
Dan
  • '67 L6 Convertible
    • L6Ragtop
« Reply #5 on: July 10, 2006, 11:51:47 PM »
Quote
Quote
Actually, the outside hole in the exhaust manifold ear is a locating pin (see link).  The outer most mounting bolts span both manifolds and are spec'd to 20 ft-lbs.  All of the center mountings, a combination of studs and bolts, are spec'd to 30 ft-lbs.
http://mysite.verizon.net/pacesetter.camaro/L6Manifold.jpg
Dan
« Reply #6 on: July 11, 2006, 03:44:57 PM »
Shows how much I know about L-6's - I just took the specs from the Chassis Service Manual, which has a spec for the "end bolts" on the L-6.  ::)
Dan
    • L6Ragtop
« Reply #7 on: July 11, 2006, 04:48:37 PM »
I'm afraid we L6s are a just about extinct.    8)
Dan
rich69rs
  • LF7/M35/Z22/Z87
« Reply #8 on: July 11, 2006, 06:26:56 PM »
Hang in there Dan -
Saw a very nice '67 last weekend, 250 badges on the fender.  Car was at a local car show.  Hood was up and there was the original, 6 cyl with air conditioning.  Very nice - I believe in the 15 yrs I've had my '69 327 RS coupe, I've actually seen less than 5 L6 cars.  Keep the fairth!
« Last Edit: July 11, 2006, 06:28:29 PM by rich69rs »
Richard Thomas
1969 RS
