Author Topic: Stupid Question - What does Sway Bar Rubber Sleeve/Clamp do?  (Read 12233 times)
Hans L
« on: February 06, 2012, 05:02:40 PM »
Ok, restored and re-installed the sway bar sleeve and clamp assembly over the weekend (the round rubber bushing next to the sway bar bracket).   So what does this thing do??  Prevent some lateral motion/sliding of the sway bar?  Sqeaking??  I don't recall my other GM cars having this ('69 Chevelle).
'69 Chevelle SS 396 4 Speed
Re: Stupid Question - What does Sway Bar Rubber Sleeve/Clamp do?
« Reply #1 on: February 06, 2012, 07:16:20 PM »
It prevents lateral motion - keeps the bar centered.
« Reply #2 on: February 06, 2012, 07:47:38 PM »
I've been at this for a long time and I've never seen a front sway bar the wasn't painted black at the factory.
Hans L
« Reply #3 on: February 06, 2012, 07:50:03 PM »
OK.  I was suspecting lateral movement.   Regarding color - if black is correct, easy to fix.  Assume a lower luster black - like "30%"?
DT
« Reply #4 on: March 20, 2012, 08:16:40 PM »
I thought the sway bar color was Dark Phosphate ?
Donny
« Reply #5 on: March 20, 2012, 08:43:13 PM »
Nope-dip painted black.
Hans L
« Reply #6 on: March 21, 2012, 09:50:06 PM »
By the way, corrected the finish of the sway bar to black, though sprayed, not dipped:
DT
« Reply #7 on: March 21, 2012, 10:57:58 PM »
Very nice!  Which black did you use on the sway bar ??
Donny
Hans L
« Reply #8 on: March 21, 2012, 11:06:12 PM »
Not sure how correct, but I used Krylon semi-gloss spray paint,  per referencing the following sources & CRG feedback: http://www.67z28.com/finishes.htm
68rs327conv
    • The build
« Reply #9 on: March 22, 2012, 12:27:01 AM »
I believe the sway bar bracket should also be painted black.
68 RS Conv 327/210hp, Powerglide Factory AC
« Reply #10 on: March 22, 2012, 02:51:32 AM »
Wasn't all the parts that were *dipped* in black, dipped in the 'satin black' (like the reconditioning black?).. semi flat is closer than semi gloss.... if you're using kyrlon or the like..
DT
« Reply #11 on: March 22, 2012, 02:25:12 PM »
I painted my sway bar phosphate because I was on HeartBeat City's web site and they list the color as phosphate in the sway bar description.  So black is it then.  Thanks
http://www.heartbeatcitycamaro.com/store/product/18353/Camaro-Front-sway-bar-HD-COPO-13-16-69/
Donny
NoYenko
« Reply #12 on: March 28, 2012, 12:13:33 AM »
Hans, over the weekend I took my swaybar pieces apart to refinish and noted the 360 degree bushing clamps were dark phosphate on both. See photo. George.
« Reply #13 on: March 28, 2012, 05:05:22 AM »
Isn't it likely that they were phosphated after manufacture, shipped to the assembly plant, then painted black after assembly onto the subframe?
Sauron327
« Reply #14 on: March 28, 2012, 11:33:01 AM »
Subframes were not painted as an assembly.
