May 25, 2013, 02:40:22 PM
Search:     Advanced search
82262 Posts in 10507 Topics by 4352 Members
Latest Member: NCCaprice
+  CRG Discussion Forum
| |-+  Originality
| | |-+  Is this the oil pressure line hole?
« previous next »
Pages: [1] Print
Author Topic: Is this the oil pressure line hole?  (Read 969 times)
1967RS/SS
Member
View Profile Email
« on: January 09, 2012, 10:19:42 PM »
Is this the oil pressure gauge line hole and grommet just above the plastic ducting and to the right of the steering column boot?  The reason I am unsure is because my car also has an open hole behind the accelerator pedal.
Logged
68Zproject
Hero Member
View Profile Email
« Reply #1 on: January 10, 2012, 12:02:07 PM »
If you mean the rubber thing, no.  That's what holds the firewall mat to the firewall. If you look from the engine side toward your firewall, you should see this rubber nib sticking out.
Logged
68Z28
big iron
Member
View Profile Email
« Reply #2 on: January 19, 2012, 02:33:58 PM »
Need info.
What is your build date?
Is the console w/ gauges original to the car?
Bob
Logged
68Zproject
Hero Member
View Profile Email
« Reply #3 on: January 19, 2012, 11:37:52 PM »
Firewall side.
Logged
68Z28
big iron
Member
View Profile Email
« Reply #4 on: January 20, 2012, 02:14:36 PM »
Early 67's with U17 had a 2 pc. oil line with a bulkhead connector on the firewall. Was changed to a 1pc. line and rubber plug as shown around 05 or 06
of 67.
Bob
Logged
Hero Member
View Profile
« Reply #5 on: January 20, 2012, 08:30:38 PM »
of 67.
Bob
I checked my NOR 67 with a trim tag date of 5B and the oil line is a 1 piece unit using the rubber grommet.
Logged
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
big iron
Member
View Profile Email
« Reply #6 on: January 20, 2012, 09:18:03 PM »
Do search ( oil lines for 67 cars with gauges ) . Check BrianK's reply #6 . Also discussed over on TC.
Bob
Logged
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.101 seconds with 17 queries.
