Author Topic: Bucket Seat Back teather cable  (Read 37151 times)
MyRed67
  • SZZLN 67
« on: December 23, 2011, 11:24:13 PM »
  Anyone on here know where I might find the Bucket Seat hinge teather cable?  Runs along inside hinge on each seat from the  seat back to the seat main frame.  I can find the screw for each end but not the cable.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: Bucket Seat Back teather cable
« Reply #1 on: December 24, 2011, 12:20:40 AM »
It's only on the passenger seat (driver doesn't need one since the seat back hits the steering wheel when pushed forward), and as far as I know, no one is reproducing them. Used would be your best bet.
The original part number (in Group 11.381) was 7726498 and it was also used on the 67-69 Corvair Monza. If you want I can ask my buddy Jeff at CALIFORNIA CORVAIR'S if he has any. He won't be back until next week though (Christmas vacation).
68Zproject
« Reply #2 on: December 24, 2011, 05:07:31 AM »
ED, I'd be interested in one too if he has them.  There is a thread on TC where someone got the exact dimensions and made one.  I'll look it up.  The pictures were missing, sorry.
68Z28
MyRed67
  • SZZLN 67
« Reply #3 on: December 24, 2011, 08:23:33 AM »
>>>>>Ed;
   Yes, I would be interested in one of these cables.   I didn't realize this cable was only on the Pass. seat, that would explain why it was completely missing from the Driver seat(screws and all).   I have the broken cable and the 2 screws for the Pass. seat, cable rusted through and broke right in the middle.  I was thinking if I really had to a new one could be made with a new piece of cable and the 2 original ends.
1967 Camaro  LOS  11A
IZRSSS
  • Guest
« Reply #4 on: December 24, 2011, 02:36:08 PM »
Is this the cable guys? If it is, can it be adjusted because the seat-back hits the dash?
And, if anyone needs better pics and demensions let me know. I'll see if I can pull it and post.
lakeholme
  • 68-12D L30/M35
« Reply #5 on: December 24, 2011, 03:12:03 PM »
Get ur done!
Marty, mine has a five inch cable and still misses the dash by about an inch and a half with the seat all the way forward.
Your picture looks like the cable still has a little slack in it???
lakeholme
  • 68-12D L30/M35
« Reply #6 on: December 24, 2011, 03:39:42 PM »
IZRSSS
  • Guest
« Reply #7 on: December 24, 2011, 03:48:11 PM »
You learns somethen evrr da...
« Reply #8 on: December 24, 2011, 06:01:05 PM »
Ok guys, after the holiday I'll see what he can dig up for us (Yep. Me too. Mines' broken.)
Marty, if your seat is hitting the dash and you still have that much slack, there's something wrong. Measure the cable and see if it's the same as ours.
joesauer
« Reply #9 on: December 24, 2011, 06:48:48 PM »
Spent close to a year looking for a supplier, found none.  Made one myself, using a damaged one as a model.   If it helps......overall length is 7 in., end connectors are 1 3/8 long with 3/4 OD, and 7/16 ID hole.  Cable is 1/8 in diam. uninsulated.  Grey insulation extends 1 in. past end of connectors (center 2 1/4 of cable is uninsulated).  These dimensions were off the damaged cable on my '68.
Danzo
« Reply #10 on: December 30, 2011, 12:01:29 AM »
Joesaur
 Where did you buy the ends from and what did you use for insulation?
Thanks.
IZRSSS
  • Guest
« Reply #11 on: December 30, 2011, 01:37:09 AM »
Will do...thanks Ed.
MyRed67
  • SZZLN 67
« Reply #12 on: December 30, 2011, 02:57:10 AM »
 Posting a pic of mine from my '67, as they are a little different.  The whole cable is coated black on mine, and the ends are not coated.   Overall length seems to be the same.  Connector length also seems the same.  My Camaro is relatively early, maybe they changed sometime during production.
1967 Camaro  LOS  11A
joesauer
« Reply #13 on: December 30, 2011, 07:41:01 PM »
Danzo,
When I made a new cable (about 2 years ago),  got the end connectors (Cable lugs) fron a local electronics parts supplier (in the SF Bay Area).  You may be able to get them on line or from a local auto parts store.  Mine are heavy duty, not the cheapie thin gauge aluminum you may see at Radio Shack.  I used ones that were intended for engine bay connections.  I crimped and soldered the connections, then filed off any excess solder.   As to the insulation, I used the canned stuff (can't remember the brand) that's used to dip you pliers, etc. in to put insluation on the plier handles.  Sprayed the finished product black to match my seats.
IZRSSS
  • Guest
« Reply #14 on: January 08, 2012, 05:42:48 PM »
Ed - I finally had a chance to take a look at this; "Seat Back Stop Cable". As you can see by the pics, whoever upholstered the seats didn't bother reinstalling it to the seat-base. They simply left it on the hinge. Guess I was lucky they didn't just toss it in the trash. Is it safe to assume the red arrow in the first pic is the general location for anchoring the cable to the base? I'm pretty sure I can feel the female end of the bracket underneath the upholstery in that general area.
Second, can someone tell me where I can find the correct washer and screw in the second pic…AMK Products maybe?
And last, can someone post a pic of theirs anchored in the correct position w/the correct hardware?
tmodel66
« Reply #15 on: January 08, 2012, 05:55:27 PM »
AMK has the correct bolt and washer. I got it in my new bolt kit and they look identical including correct head markings.
Daniel
lakeholme
  • 68-12D L30/M35
« Reply #16 on: January 08, 2012, 05:57:41 PM »
http://www.camarocentral.com/1967_1970_RH_Front_Bucket_Seat_Cable_Strap_Bolts_p/int-868.htm
Apparently, you supply the actual cable???
Camaro Central has the correct head screws and pivot shoulders, as well.
IZRSSS
  • Guest
« Reply #17 on: January 08, 2012, 06:09:22 PM »
Daniel - If its not too much trouble can you send me a pic of the hardware you received from AMK. I'd like to compare it to the hardware on reply/pic #4.
Thanks Phillip...
tmodel66
« Reply #18 on: January 08, 2012, 06:35:01 PM »
It'll be tomorrow but I'll get it no problem.
Daniel
« Reply #19 on: January 08, 2012, 08:03:19 PM »
Sorry guys. I haven't had a chance to speak to Jeff yet, but I promise I'll call him Tuesday. So how many guys need the cable?
68Zproject
« Reply #20 on: January 08, 2012, 10:45:43 PM »
One here.
68Z28
MyRed67
  • SZZLN 67
« Reply #21 on: January 08, 2012, 10:52:10 PM »
Ed,  I'm still interested.
1967 Camaro  LOS  11A
srode
« Reply #22 on: January 09, 2012, 01:00:25 AM »
I need 2, one for each of mine if you can get them.
Steve - 02D Z11 and a Plain Jane hardtop
adjudimo
« Reply #23 on: January 09, 2012, 11:27:25 PM »
My 67 is missing it all. I too would be interested. Thanks.
Dave69x33
« Reply #24 on: January 10, 2012, 02:00:55 AM »
Hi Guys,
Here are some pictures of an original replacement tether cable I have on my '69. My original was missing, so I purchased a very clean used original.  I lightly wire brushed the hardware on my pedestal grinder then waxed them to give some protective coating. The hardware is original for reference.
Good luck with your projects to reproduce the cables.
Dave
« Reply #25 on: January 11, 2012, 05:50:48 PM »
Ok guys. I just spoke to jeff and he's going to see what he has and call me back. It may take a few days to get to the seats (they're in a different storage area), so stay tuned.
MyRed67
  • SZZLN 67
« Reply #26 on: January 12, 2012, 07:00:05 AM »
Thanks for checking Ed!
1967 Camaro  LOS  11A
« Reply #27 on: January 19, 2012, 07:10:35 PM »
Well, the news isn't good guys.
I just spoke to Jeff and he does have several sets of seats, but most of the cables are broken, missing, cracked, etc... The two that he found that were still in good shape are attached to seats that are also in good shape, so he doesn't want to pull the cables off and sell them separately.
Looks like we're back to the drawing board on this one.
adjudimo
« Reply #28 on: January 19, 2012, 08:20:32 PM »
Thanks Ed, I appreciate the effort and will just consider it another wow factor if I do stumble across a set. Can't blame your friend for not wanting to seperate. I wouldn't either. J.R.
srode
« Reply #29 on: January 20, 2012, 02:31:07 AM »
Thanks for trying Ed, much appreciated.
MyRed67
  • SZZLN 67
« Reply #30 on: January 20, 2012, 03:05:02 AM »
Ditto, Thanks Ed!
1967 Camaro  LOS  11A
joesauer
« Reply #31 on: January 20, 2012, 05:25:11 PM »
This cable is not difficult to make (see my earlier post).  Mine may not pass judging, but it definitely protects the dash/glove box from being hit by the passenger seat.  I used 1/8 inch diam. stranded cable for the center section as I'm not sure exactly what the factory used.  Think that's the only deviation from original.  Anyone know for sure what color the insulation was.  See many photos with grey.
IZRSSS
  • Guest
« Reply #32 on: January 20, 2012, 09:10:56 PM »
Finally got around to pulling the seat out to get to the cable. Here are a couple of pics. Both the cable and blade connector's insulation is gray. I Also included a few dimensions. Note; blade connectors are offset to one another.
If there's anything else you'd like better pics of let me know.
lakeholme
  • 68-12D L30/M35
« Reply #33 on: January 21, 2012, 02:30:28 AM »
The cable on my 68 is black. The ends are coated and gray like Marty's.
Maybe they did change as time went on?
Sauron327
« Reply #34 on: January 21, 2012, 02:37:45 AM »
Hunt Craigslist for every seat you can find and ask the seller to part with one. Or try E-bay. I got mine from cars I parted out.
MyRed67
  • SZZLN 67
« Reply #35 on: January 21, 2012, 04:30:23 AM »
As I posted earlier, on my 67 the cable insulation is Black and the spade end connectors are not coated.  I'm thinking if I heat up the ends, I may be able to pry them open.  I have some spray Black plastic coating.  I'm thinking if I can get the original ends off, I can put them on a new piece of cable and re-crimp them, maybe even silver solder them .
1967 Camaro  LOS  11A
joesauer
« Reply #36 on: February 15, 2012, 05:56:14 PM »
Any updates on a source for pass. seat teather cable?  I sprayed my home made one black to match the seats......but wondered what the factory original cable color was.
lakeholme
  • 68-12D L30/M35
« Reply #37 on: February 15, 2012, 10:41:00 PM »
We need John or somebody with a documented car to look at their strap.
« Reply #38 on: February 15, 2012, 11:53:28 PM »
 I just checked both my '67 Camaros and found the following:
NOR 5B 760Z standard black interior (restored interior but used same cable) - gray cable coating and gray heat shrink ends
LOS 4B 760Z standard black interior (original survivor interior) - black cable coating and black heat shrink ends
Neither car has a cable on the drivers seat.
I think it may be safe to assume there were multiple colors.
« Last Edit: February 16, 2012, 12:41:00 AM by 67-Z27 »
« Reply #39 on: February 16, 2012, 04:15:33 PM »
My 02D Norwood '69 (Midnight Green deluxe interior) has a white strap with gray heat-shrink ends.
lakeholme
  • 68-12D L30/M35
« Reply #40 on: February 16, 2012, 10:25:06 PM »
How about a red interior, anybody?
Boston14
« Reply #41 on: February 17, 2012, 04:19:33 AM »
My 11D Norwood (Red standard interior) has a white strap w/gray heat-shrink ends like JohnZ. I can attach a picture tomorrow.
boston14
boston14
1969 SS/RS 350 Convertible
Boston14
« Reply #42 on: February 18, 2012, 12:16:22 AM »
Here's my seat cable -  the seat is pretty dirty from storage, but all original.
boston14
boston14
lakeholme
  • 68-12D L30/M35
« Reply #43 on: February 18, 2012, 08:18:54 PM »
Looks like the cable was white, gray, or black, and perhaps random...
« Reply #44 on: February 18, 2012, 10:14:16 PM »
In post #76 I said my NOR was gray with gray ends, but looking at the picture Boston14 posted, that is more of what I have. It looks more like an off white (towards gray) to me.
So it looks like we are back to either "white" or black cables with either gray or black heat shrink ends.
joesauer
« Reply #45 on: February 19, 2012, 05:45:53 PM »
My beat-up original cable (before I built a new one) had gray vinyl where center section meets the connectors, and a black center.  Metal ends were unpainted.  This was off a 68 LA build, Jan 1968.
flyingskibiker
« Reply #46 on: February 22, 2012, 03:40:23 AM »
Not sure if this helps, but my buckets are out of a '67 Firebird.  They had standard covers and headrests.  The cable, broken already when I bought the car in '83, is grey/grey.
IZRSSS
  • Guest
« Reply #47 on: February 22, 2012, 03:58:59 AM »
Quite frankly I don't see any difference between my strap and that of Boston14's. They are both gray/gray or white/gray depending on the light, exposure, and camera used. I can take several pics of the same strap and everyone would be diff...
tmodel66
« Reply #48 on: February 22, 2012, 03:32:09 PM »
Here's mine  07A Norwood car. Grey with grey ends.
Daniel
1967RS/SS
« Reply #49 on: July 08, 2012, 05:08:27 PM »
Here is mine off my 01C 67 SS/RS deluxe interior.
1967 RS/SS L-48
Van Nuys 01C
Joseph
ZLP955
« Reply #50 on: December 18, 2013, 09:23:20 AM »
Know this is an old thread, but there's one currently listed on eBay HERE. Best do your homework to check originality and correct application, as it has a black cable (rather than gray) and appears to be lacking heat shrink over each end. But it does look similar to the strap from a '67, picture posted towards the bottom of page 1 by MyRed67.
Tim in Australia.
MyRed67
  • SZZLN 67
« Reply #51 on: December 19, 2013, 06:48:52 AM »
Thanks Tim, it looks exactly like mine.  I bought it, 'cause it's rare to find 'em.  And it looks to be a very nice original. It took 2 years, but CRG comes through again.  Thanks Guys for keeping this alive!
1967 Camaro  LOS  11A
sdkar
« Reply #52 on: December 19, 2013, 03:19:43 PM »
I have a couple of these I found in my misc. Camaro parts bin.  They are from a 69 and are grey, and about 7" long.  Not sure what they are worth, but if you are looking for one, email me and make me an offer.
sdkar@bellsouth.net
sdkar
« Reply #53 on: December 21, 2013, 12:55:36 AM »
Here is a pic of them...
sdkar
« Reply #54 on: December 21, 2013, 04:35:06 AM »
Just to let everyone know, these have found a new home and no longer available.  Thanks.
sdkar
« Reply #55 on: January 18, 2014, 03:06:58 AM »
If you are interested in getting a reproduction seat cable, check out other postings here...
http://www.camaros.org/forum/index.php?topic=11730.0
