CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
May 23, 2013, 04:44:13 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
82185 Posts in 10499 Topics by 4350 Members
Latest Member: clydehale25
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  General Discussion
| | |-+  ? 69 Pace Car on EBay?
« previous next »
Pages: [1] 2  All Print
Author Topic: ? 69 Pace Car on EBay?  (Read 1677 times)
MyRed67
Member
Almost there!
michael-l.campbell@hotmail.com
View Profile
« on: November 26, 2011, 03:18:47 PM »
 This 69 Pace Car listed on EBay, what do you guys think?  It is possible?  Is it true that the LA "Pacers" didn't have the Z11 on the Cowl Tag?
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200680006065#ht_37162wt_1131
Logged
1967 Camaro  LOS  11A
Mark
CRG Member
View Profile Email
« Reply #1 on: November 26, 2011, 03:38:58 PM »
No Z11 code on any LA built Pace Cars, also no Z10s ever built there, and no X codes on any LA built car.  Any white convertible with white top, and orange houndstooth interior built at LA is a pacecar.
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
MyRed67
Member
Almost there!
View Profile
« Reply #2 on: November 26, 2011, 07:43:28 PM »
So, it looks to be original as claimed?   Would the J480 in the lower right corner be interplant tracking #?  J 10 th. day, 480 th. car?
Logged
1967 Camaro  LOS  11A
Hero Member
View Profile
« Reply #3 on: November 26, 2011, 08:51:34 PM »
That's the Fisher Body body scheduling code.  From CRG...
"The LOS (Los Angeles/Van Nuys) body scheduling code is a letter followed by one to three digits, e.g., F103. Based on data analysis only (there is no GM documentation yet available that describes this code) - but with consistent application to thousands of datapoints - CRG believes the code was used by LOS Fisher Body (and other plants that built multiple carlines) to aid in scheduling the body build order.
The letter indicates the approximate production day of the month for the start of the assembly of each vehicle body. It began with letter "A" on the first day of the month of the Fisher production calendar, incremented at the start of each additional production day to the next alphabetic letter, and was reset to letter "A" at the start of the next production month. (Note that the Fisher production calendar is known to differ slightly from the calendar month, and we also do not yet know exactly how the Fisher production calendar related to the Chevrolet monthly production reporting calendar.)
The one-to-three digit sequence number that follows the letter was reset to 1 at the start of each production day and was incremented serially with each body built by the factory as the day progressed. Data analysis indicates that the sequence number at the LOS plant was assigned regardless of model or body type. By this we mean that Camaros and full-size passenger cars both incremented the same sequence counter. The unit counter was reset to 1 the next day as the day-of-the-month code letter incremented to the next letter. In the example, F103 would indicate the sixth day of production for a given month and the 103rd body started on that sixth day of production.
Logged
MyRed67
Member
Almost there!
View Profile
« Reply #4 on: November 27, 2011, 12:27:23 AM »
 Yeah, that's what I meant, I guess it might be called something different in different circles.
Logged
1967 Camaro  LOS  11A
Charley
Member
View Profile WWW Email
« Reply #5 on: November 27, 2011, 12:41:04 AM »
I'm impressed with the guys great pictures and description of the car. I have owned at least one LA Pace Car that had Z11 on the build sheet. Should have made copies.
Logged
Oaklyss
Member
View Profile Email
« Reply #6 on: November 27, 2011, 12:03:17 PM »
Anyone notice the steering wheel? wonder if its original? He should check on top of the gas tank for the Broadcast Copy. If the tank was never removed, It will be there.
Logged
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built
IZRSSS
Guest
« Reply #7 on: November 27, 2011, 01:04:24 PM »
It looks like the same Steering Wheel option in this report (April 69 "Cushioned Rim", steering wheel). Scroll down just a bit and you'll see it; http://www.camaros.org/swheel.shtml#69
Here is a quote from the report which states how rare these wheels are;
The RPO NK1 "Cushioned Rim" steering wheel was introduced in the April 1969 dealer information (right), however the factory production totals indicate that no 1969 Camaro came equipped with this wheel. Recently, a car with window sticker documentation has been discovered that has NK1 and there is also a Canadian documented car with NK1.
Logged
CRG Member
View Profile Email
« Reply #8 on: November 27, 2011, 01:55:29 PM »
As the hub doesn't match the wheel is probably not OE.
The owner should end the auction now and take the current bid. Plenty of money for this very rough car.
Logged
IZRSSS
Guest
« Reply #9 on: November 27, 2011, 02:42:56 PM »
Bill - What are the tall tale signs this wheel isn't original? I looked at both the hub in Ed's report and the one on eBay. It looks like the center spoke of the eBay wheel will fit in the notch/cut-out of the hub shown in Ed's report?
Thanks!
Logged
CRG Member
View Profile Email
« Reply #10 on: November 27, 2011, 02:47:15 PM »
The hub would have been painted black to match the column. Looks NOS or repro to me.
Logged
IZRSSS
Guest
« Reply #11 on: November 27, 2011, 02:50:16 PM »
Thanks again!
Logged
jl8dale
Member
View Profile Email
« Reply #12 on: November 27, 2011, 05:44:32 PM »
Restoring this car will be expensive and when done the new owner will have a 350 pace car with no docs and a non original motor.
Probably worth somewhere in the 30's. At 12k, he should take that and run with it.
No bargain here.
Logged
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
1969 Pace Car Original & Highly Optioned - Chassis Broadcast Sheet
Member
View Profile Email
« Reply #13 on: November 28, 2011, 12:49:25 AM »
 Cheesy
Funny, My car is L529677 also a LOS 04C build, Very close to the one for sale. <529407>
For comp,,,,, My tag = M044 His = J480
The Chassis Broadcast Copy (Mine) does in fact Have Z11,,,,,,"5Z11AA", "5Z87KM", "5Z720BA" typed in below all the data blocks.
Very quickly someone will become upsidedown on this car.
Logged
Kelley W King
Member
View Profile Email
« Reply #14 on: November 28, 2011, 08:41:44 AM »
His write up sounds like he knows a good lawyer.
Logged
69 Z28 RS
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.106 seconds with 17 queries.
