Author Topic: 1967 Z28 on eBay  (Read 4265 times)
Re: 1967 Z28 on eBay
« Reply #1 on: November 24, 2011, 11:26:34 PM »
Beautiful colors. Kind of makes you wonder why it doesn't  run. And it doesn't say it has the original engine, does it?
69z28302
« Reply #2 on: November 24, 2011, 11:43:25 PM »
This is like the third time it's been listed. I'm like you, doesn't seem like it would take much to finish. I'd like to have it.
IZRSSS
  • Guest
« Reply #4 on: November 25, 2011, 01:18:05 AM »
That's what I was thinking, at least until I took a look at Paul's link :-\. Have you ever heard of any Z, especially a '67 ending at <28K ??? Major red flag!!! Again, where in the heck are the important numbers and pics to go along with these numbers (Vin, engine pad, tranny & rear)?
Hmmm...blow up the pic of the cowl tag & check out the rivits. What a mess  :o
« Last Edit: November 25, 2011, 01:41:25 AM by IZRSSS »
« Reply #5 on: November 25, 2011, 02:14:17 AM »
Not sure if correct but on team camaro it was stated the car was suspended from the 67 Z/28 registry and it had a repro cowl tag. No expert here but very little real info to go on and as long as its been on ebay you would think they would have gotten that engine running.
Here is the link from the past discussion:
http://www.camaros.net/forums/showthread.php?t=201458
IZRSSS
  • Guest
« Reply #6 on: November 25, 2011, 03:17:11 AM »
Thanks for the TC thread Chick. Its all coming together now! :P
MyRed67
  • SZZLN 67
« Reply #7 on: November 25, 2011, 07:39:16 AM »
IF it is in fact a 3892657 Block, what did they do with the Crankcase vent hole in the back of the Block?  Did they block it off?  Clearly has the vent tube to the Air cleaner coming off of the Pass. Valve Cover.  Which has already been stated are not correct for a '67.  And the PCV Valve should be in the Oil Fill Tube.  Lots of Red Flags.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
restore-z28
« Reply #8 on: November 25, 2011, 01:22:33 PM »
Chick thanks for posting the thread to the Team Camaro site as I was sure I read about this car somewhere. Seem very odd they would go through all this effort for a professional restoration and then 2 feet away from the finish line just stop...
Sonny
1969 Z28 Camaro, sold :-(
1970 Z28 Camaro
www.camaros.ca
« Reply #9 on: November 25, 2011, 04:13:04 PM »
Also has a '68 deck lid, and gotta love the K-Mart battery cable terminals.
