Author Topic: Quarter Window Adjustment  (Read 9419 times)
tmodel66
« on: November 16, 2011, 03:51:23 PM »
My quarter window is stiff, hanging up and seems to jam sometimes to a point I have to actually pull up on it to get it to roll up. Anybody have this problem? My regulator and tracks are all good and no slop anywhere. Any ideas how to fix this?
IZRSSS
  • Guest
Re: Quarter Window Adjustment
« Reply #1 on: November 16, 2011, 04:37:38 PM »
Do you have a fisher body service manual? All the adjustment procedures are in there.
tmodel66
« Reply #2 on: November 16, 2011, 04:40:03 PM »
I have adjusted the window so the fit is right. My problem is the stiff places and the jamming up so I have to pull up on it.
IZRSSS
  • Guest
« Reply #3 on: November 16, 2011, 04:51:41 PM »
Here are a few links I found over at TC. I didn't have a chance to go through each one of them but you might find something that works for ya.
http://www.camaros.net/forums/gtsearch.php?cx=partner-pub-7865546952023728%3Afkajkqpysat&cof=FORID%3A11&ie=UTF-8&q=1%2F4+window+adjustment&siteurl=www.camaros.net%2Fforums%2F
joesauer
« Reply #4 on: November 16, 2011, 05:08:49 PM »
Had a similar problem on my 68.  Even though everything looked ok, turned out to be a worn center shaft on the lower nylon roller.  Not a difficult repair job if you take your time.  Took out rear seat, removed quarter trim panels & watershields, etc.  Degreased mechanisms, replaced all rollers, regreased, adjusted, etc.   Have you replaced the quarter trim panels or weatherstripping recently?  Sometimes the aftermarket stuff does not fit correctly, & causes binding.   Anyway......degreasing & relubricating the mechanisms can't hurt.
tmodel66
« Reply #5 on: November 16, 2011, 05:47:15 PM »
Doing a restoration and we're putting it back together. I haven't got any molding on it so it's not hitting or catching anything.
« Reply #6 on: November 26, 2011, 01:33:02 AM »
Can we assume all the old lube was cleaned from the regulators/guides & they were checked for wear and before reassembly the correct lubricants were reapplied as specified in the Fisher Manual?
jl8dale
« Reply #7 on: November 26, 2011, 01:39:29 AM »
I have had the same issues and it was the roller.
It could be loose or broke. In my case it was loose and the roller was moving around on the glass causing it to jam up.
They make a special tool to tighten the washer nuts to the glass.
It has two prongs on it and is relatively inexpensive.
It's best to take ou the window and inspect off the car.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
tmodel66
« Reply #8 on: November 27, 2011, 06:50:31 PM »
Got it fixed. I guess after all the moving around, taking apart, cleaning it had a pinched place in the track. It was small enough you couldn't see it but you could feel the bulge like it had been stepped on or something.
« Reply #9 on: November 28, 2011, 04:59:26 PM »
Sometimes what seems to be inconsequential turns out to be the grain of sand that stops EVERYTHING!!! Glad you got her fixed!
