Author Topic: A Frame Splash Apron - tucked or not?  (Read 6461 times)
srode
« on: October 01, 2011, 12:38:11 PM »
Took my car to a cruise night last night and while walking around looking at other people's cars I noticed 100 % of the Gen1 Camaros had the T on the A Frame splash apron laying on top of the A Frames and not tucked in the center hole in the A Frame - Always thought they were supposed to be tucked in the hole. Which way is correct?
IZRSSS
  • Guest
Re: A Frame Splash Apron - tucked or not?
« Reply #1 on: October 01, 2011, 01:33:04 PM »
Steve - you are correct. It should be tucked in center hole of A-Frame.
tmodel66
« Reply #2 on: October 01, 2011, 01:40:30 PM »
Interesting cause I've never saw them tucked in either. Maybe somebody with a survivor will chime in. John, Kurt where are ya'll?
IZRSSS
  • Guest
« Reply #3 on: October 01, 2011, 02:45:00 PM »
Steve - here you go...fuel lines;
Mark
« Reply #4 on: October 01, 2011, 03:30:50 PM »
Why would GM cut them to fit into the upper Arm hole if they weren't intended to be in there?  What do you think happens to the sheild if its not tucked in when water from a puddle hits them going 30 or 40 mpg, it lifts it up and the water and mud spray all over your engine compartment.  Yes, these cars were originally made to be driven everyday in the rain and snow.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #5 on: October 01, 2011, 05:30:53 PM »
Yes, the seal flaps should be tucked under the upper control arm, as designed, and as shown in the Assembly Manual; can't imagine anyone thinking the flap just hangs out in the air. As the old adage says, "If all else fails, read the instructions".  ;D
srode
« Reply #6 on: October 01, 2011, 05:52:23 PM »
Thanks guys, thought so.   There's a bunch of guys out there that think differently apparently.
srode
« Reply #7 on: October 02, 2011, 01:15:52 AM »
BTW, thanks for the fuel line pictures, very helpful!
