Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
68 coil bracket w/ cowl plenum
« previous
next »
Print
Pages: [
1
Author
Topic: 68 coil bracket w/ cowl plenum (Read 3126 times)
70L34
Member
on:
September 24, 2011, 11:01:57 PM »
Hi all, is there any special coil bracket required for the cowl plenum option on a 1968 302? My coil seems to be interfering with the air cleaner. Thanks, Tony
Tweet
Logged
Hero Member
Re: 68 coil bracket w/ cowl plenum
Reply #1 on:
September 24, 2011, 11:16:50 PM »
I'm not aware of any difference in the coil bracket from std. air cleaner to cowl plenum. Just curious if your coil is bottomed out in the bracket? Assume your interference is bottom of cleaner base to coil wire/coil?
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
70L34
Member
Reply #2 on:
September 24, 2011, 11:18:46 PM »
Hmm, not sure if the coil is bottomed out or not. I'll check. Thanks!
Logged
GaryL
Hero Member
Marilyn and me
Reply #3 on:
September 26, 2011, 04:11:08 AM »
Isn't the bracket slanted more for the cowl air cleaner than the open element? It is for the '69 model.
Logged
Gary
Print
Pages: [
1
« previous
next »
Originality
