Author Topic: rad support to frame nuts and bolts.  (Read 4209 times)
lynnbilodeau
« on: September 06, 2011, 06:19:57 PM »
Well, I am finally doing a test fit of all panels to make sure everything lines up before final painting.  I did a good job of indexing and marking most of my bolts for storage.  Unfortunately, I haven't (yet) found the nuts and bolts I need for the radiator support to the front of the subframe.  Can someone give me the exact size of the originals (or even better, anyone have some usable originals I can buy)?
Thanks for any help.
Lynn
Re: rad support to frame nuts and bolts.
« Reply #1 on: September 06, 2011, 07:58:07 PM »
LEFT - REPRODUCTION:  No Center mark- 6 radial marks (Grade 8 ), no step on the shank, blunt tip.
RIGHT - ORIGINAL: Center marked (E) - 3 radial marks (Grade 5), stepped shank, pointed tip.
UPPER of the Two -- ORIGINAL            LOWER - - Reproduction from Rick's /Ecklers.
Here is the set-up with the push on (spring steel) retainer which makes it so simple to install the rad support... (most omit this detail)
lynnbilodeau
« Reply #2 on: September 07, 2011, 02:01:57 AM »
Thanks a million.  I am sure I have the originals somewhere, and now know what to look for.
Lynn
« Reply #3 on: September 07, 2011, 09:27:48 PM »
Where'd you get the spring retainer?
« Reply #4 on: September 07, 2011, 09:35:39 PM »
local fastener supply house... they are very inexpensive, they are also available at most local body shop supply houses, and
i have bought them at Larger swapmeets, like Charlotte Autofair or Hershey AACA.
lynnbilodeau
« Reply #5 on: September 09, 2011, 01:29:46 AM »
Thanks for all the info, and a special thanks to the member here who found some and sent me a private pm.
I found my originals complete with nuts and washers and even the original mounting bushings.
Lynn
« Reply #6 on: September 09, 2011, 11:19:14 PM »
Is there a specific size to ask for?  I don't think mine had anything left on them when I took it apart, so I don't have anything to go by.
tmodel66
« Reply #7 on: September 09, 2011, 11:34:20 PM »
They are sized like nuts and bolts. 1/2   5/8  etc.
