Author Topic: Oil Pan Drain Plug Leak  (Read 13421 times)
IZRSSS
  • Guest
Re: Oil Pan Drain Plug Leak
« Reply #15 on: September 03, 2011, 06:53:29 PM »
John, Bob, Daniel, & Sonny - Thanks for all your help!!! The consensus weighs heavy on John's "Molded Silicone Ring" - inner. I am also glad to see John's plug pic. I think I'll hang on to mine.
I have never pulled the pan from the TH350 Trans. Can anyone tell me if this particular pan is stamped. And...has anyone out there ever restored a pan as pitted as this one? And... just in case, is EBay the only place to find a born with/NOS SB pan?
Thanks again gentleman!
« Reply #16 on: September 08, 2011, 03:27:41 AM »
Personally, I wouldn't bother with the pan. Way too much work for something that noone will see.
dutch
« Reply #17 on: September 08, 2011, 05:42:38 AM »
http://www.hpaulin.com/Catalogue/400.pdf
This link should get you to the Papco fastener catalog (I mentioned Milton by mistake earlier in my first response) where on page 128 or so they list various oil pan plug gaskets by size. These are usually white nylon pieces as shown in their lising and most auto parts jobbers use or have access to Papcp stuff or stock it cheaply..
Randy
IZRSSS
  • Guest
« Reply #18 on: September 08, 2011, 10:01:07 PM »
Kurt - you are probably right.
Thanks again Randy.
