Author Topic: Oil Pan Drain Plug Leak  (Read 9461 times)
IZRSSS
  • Guest
« on: September 02, 2011, 10:44:25 PM »
I have a very small oil leak coming from the oil pan drain plug. How can this be fixed? Does the hole have to be re-tapped, or is there something sold on the market a guy can use to correct the problem?
If it does have to be re-tapped can you tell me the best method/explain this procedure. I do not want to change the dimension of the plug (bolt).
Thanx
tmodel66
Re: Oil Pan Drain Plug Leak
« Reply #1 on: September 02, 2011, 10:56:57 PM »
Marty I would try a new gasket on the drain plug. That's probably all that's wrong. Maybe even spring for a new plug.
Daniel
« Reply #2 on: September 02, 2011, 11:23:45 PM »
If the threads are stripped, you can get an oversize plug for it at just about any auto parts store. HERE'S an example on ebay.
IZRSSS
  • Guest
« Reply #3 on: September 02, 2011, 11:55:27 PM »
Daniel, or anyone - any suppliers/vendors out there who sell NOS plugs?
Ed - if Daniel's idea doesn't work this would be an excellent alternative. Appriciate the link!
Thanks gentlemen!
tmodel66
« Reply #4 on: September 03, 2011, 12:46:56 AM »
Marty go to a dealership. These things are/were used in every engine. Nothing special about'em.
Daniel
IZRSSS
  • Guest
« Reply #5 on: September 03, 2011, 01:22:01 AM »
Here's were I'm confussed...here is a pic of the plug I have in it now & the link shows a "NCRS" plug. I'm guessing if this NCRS plug is correct I can find one from a vette vendor? Or  ???
http://cgi.ebay.com/ebaymotors/TR-OIL-DRAIN-PAN-PLUG-Corvette-Camaro-63-65-67-69-70-/360386548346?pt=Vintage_Car_Truck_Parts_Accessories&hash=item53e8b6527a
« Reply #6 on: September 03, 2011, 03:30:18 AM »
I've seen several versions of the plug (yours included), so they may have been furnished by multiple vendors. John can probably comment on this.
IZRSSS
  • Guest
« Reply #7 on: September 03, 2011, 03:58:31 AM »
Thanks again Ed.
BTW - This is the first time I've taken a pic of the oil pan. Never realized it was so pitted. I think I'll add this to my many winter projects already planned. Pull it, remove the paint and inspect. While we're on this topic, I might need a source for a correct pan replacement. Any recommendation  ??? :-\.
1968 Z28
« Reply #8 on: September 03, 2011, 04:40:38 AM »
Marty...what type material is your gasket made from....It looks rather flimsy.  Mine is made out of white plastic of white nylon.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
dutch
  • Documented Canadian 1968 Z/28
« Reply #9 on: September 03, 2011, 10:18:55 AM »
Almost any jobber can provide a new pan drain plug gasket that will fix your problem, from their stock (a new plug almost assuredly is not necessary if the old one still threads in smoothly)..
Milton from memory is one manufacturer that comes to mind - but I can't recall the exact 600 series part number they used for their gasket..
Almost guaranteed to fix the problem.
Randy
IZRSSS
  • Guest
« Reply #10 on: September 03, 2011, 12:45:18 PM »
Dang...can't slide anything past you guys. :-\   100% rawhide. :-[
Thanx for the info Randy.
« Reply #11 on: September 03, 2011, 03:06:06 PM »
Usually it's the gasket, not the plug or the threads in the pan. Photo below shows the stock white nylon gasket on the left, and two aftermarket gaskets on the right; the top one is a ribbed molded plastic item, and the bottom one is a crimped steel outer with a molded silicone ring inner. The latter item works quite well.
OG69Z
« Reply #12 on: September 03, 2011, 03:18:17 PM »
Hi Marty,
 We use these on all our cars. They are foolproof.
https://www.pegasusautoracing.com/productselection3.asp?Product=3245
Bob
tmodel66
« Reply #13 on: September 03, 2011, 03:30:17 PM »
Hi Marty,
Bob
That's what we used years ago on all our aluminum deep sump oil pans and never had any problems. I had forgot about'em.
Daniel
restore-z28
« Reply #14 on: September 03, 2011, 05:22:55 PM »
Marty I bought a drain plug gasket from Heartbeat city and it worked great. Mine also had a slight seeping from the drain plug, installed a new gasket and problem solved.
http://www.heartbeatcity.com/store/product/13444/Camaro-Oil-pan-drain-plug-gasket--GM--67-68-69/
Sonny
1969 Z28 Camaro, sold :-(
1970 Z28 Camaro
www.camaros.ca
IZRSSS
  • Guest
« Reply #15 on: September 03, 2011, 06:53:29 PM »
John, Bob, Daniel, & Sonny - Thanks for all your help!!! The consensus weighs heavy on John's "Molded Silicone Ring" - inner. I am also glad to see John's plug pic. I think I'll hang on to mine.
I have never pulled the pan from the TH350 Trans. Can anyone tell me if this particular pan is stamped. And...has anyone out there ever restored a pan as pitted as this one? And... just in case, is EBay the only place to find a born with/NOS SB pan?
Thanks again gentleman!
« Reply #16 on: September 08, 2011, 03:27:41 AM »
Personally, I wouldn't bother with the pan. Way too much work for something that noone will see.
dutch
« Reply #17 on: September 08, 2011, 05:42:38 AM »
http://www.hpaulin.com/Catalogue/400.pdf
This link should get you to the Papco fastener catalog (I mentioned Milton by mistake earlier in my first response) where on page 128 or so they list various oil pan plug gaskets by size. These are usually white nylon pieces as shown in their lising and most auto parts jobbers use or have access to Papcp stuff or stock it cheaply..
Randy
IZRSSS
  • Guest
« Reply #18 on: September 08, 2011, 10:01:07 PM »
Kurt - you are probably right.
Thanks again Randy.
