Author Topic: 69 pcv valve and factory 90degree angle hose  (Read 11526 times)
canadair
« on: August 29, 2011, 06:37:00 PM »
what did the factory pcv valve and hose look like did the pcv valve have a purple tint and was the 90 degree angle pcv hose ribbed as was the heater hoses.
Re: 69 pcv valve and factory 90degree angle hose
« Reply #1 on: August 29, 2011, 07:04:41 PM »
What size engine?
canadair
« Reply #2 on: August 29, 2011, 10:22:37 PM »
69 z 302
« Reply #3 on: August 30, 2011, 02:55:23 PM »
No ribs on the PCV hose.
« Reply #4 on: August 30, 2011, 03:17:05 PM »
They also didn't have ink jet coding on them like the current ones...
sam
« Reply #5 on: August 31, 2011, 12:58:59 AM »
purple tint started in 1970 I believe. Also the assembly line versions really don't look like the NOS or over the counter pcv valve either.
« Reply #6 on: August 31, 2011, 02:12:18 AM »
From what I found out from other members and research it was originally a spun PCV and has a different look. And they are hard to find and when found are not cheap normally. Kinda like a turned body vs. the later crimped version. I never saw a purple PCV on any of the original muscle cars from the 60's. Not sure how that got started but believe (but I could be wrong) it to be a myth like the ford caution stickers on Camaro fan shrouds.
Maybe someone can post a picture to better show the differences.
L78 steve
« Reply #7 on: August 31, 2011, 04:12:46 PM »
This is correct. The factory installed valve is a spun design. The last one I saw on ebay went for in the 300 range.
69 Z/28 Dover White. SOLD
sam
« Reply #8 on: September 04, 2011, 11:10:22 AM »
They have come down in price, especially the BB ones.
Steve Shauger
    • Vintage Certification
« Reply #9 on: September 05, 2011, 12:25:12 AM »
Generally what I have seen on original survivor cars is that they do have ribbed PVC hoses. I have certified many cars and most had the ribbed hose. The four survivor cars I own all have the ribbed hose. This is not to say they were all like that, but in my opinion the ribbed hoses were certainly used and quite typical.
Steve Shauger
Boston14
« Reply #10 on: September 05, 2011, 02:07:04 PM »
Steve, are the survivor cars you own all early cars? late cars? mid cars? or a mixture? is there a correlation between build date and if the hose had ribs or not? Thanks.
boston14
boston14
1969 SS/RS 350 Convertible
Steve Shauger
« Reply #11 on: September 05, 2011, 03:14:34 PM »
If we are just talking about 69 survivors I own both very early to late:  9B of 68, 3C of 69, 4D of 69 and 9A of 69. I also have a late 67 and mid 69. In addition I have certified many survivor first gens and the ribbed hose existed in most cases. Obviously they could have been replaced but many car were untouched and had all original hoses. Hope this info helps.
Steve Shauger
« Reply #12 on: September 06, 2011, 07:34:14 PM »
I have a GM NOS old old old stock PCV hose purchased years ago...the paper wrapper is from the 60's... it is ribbed.
jdv69z
  • 69 RS Z/28 52E
« Reply #13 on: September 08, 2011, 02:22:52 PM »
Here's a pic of the hose on my 69 Z which I believe to be original, although I can't be certain. Does this look like it?
Jimmy V.
Jimmy V.
Steve Shauger
« Reply #14 on: September 10, 2011, 02:02:53 AM »
Below is a pic of two original PCV hoses. I believe one is from a 1967 19K mile L78 and the other 50 K mile Z28. These are hoses are identical to my 4 survivor cars.
Steve Shauger
LM69Z28
« Reply #15 on: September 10, 2011, 02:25:46 PM »
Your hoses appear to have the spun "snakeskin" texture as well as the ribs. Most "original" hoses I see these days are just rubbber hoses with no texture.
Any comments
Michael Kellogg
LM69Z28 ;)
69Z28
  • 69 X33D80 Z28
« Reply #16 on: August 17, 2023, 10:35:27 PM »
I went ahead and purchased the ribbed PCV hose from Doc Rebuild and it came in today. Providing pics to view. If you need more pics let me know.
GaryC
