Author Topic: Big Block pulleys???  (Read 4494 times)
kcandc
« on: June 11, 2006, 05:21:22 AM »
I am restoring a 1968 Camaro that I bought w/o an engine. It was a big block orig. ,and I want to install a 454 I have. Can you put a short waterpump and corosponding pulleys to make it look orig? or does the 454 dampner prevent that. I have heard the 454 is balanced exterally with the dampner. Thanks, Karl It's a mid 70's truck engine.
Re: Big Block pulleys???
« Reply #1 on: June 11, 2006, 03:06:10 PM »
The 454 is externally-balanced, but the overall thickness of the damper to the pulley mounting face is the same as that of the 427; the 454 will accept the same accessory drive components as the 427 with no issues.
kcandc
« Reply #2 on: June 11, 2006, 06:48:03 PM »
That's the answer I wanted to hear, Thanks, Karl :D
