May 18, 2013, 07:50:49 AM
Search:     Advanced search
81976 Posts in 10480 Topics by 4331 Members
Latest Member: z28rush
+  CRG Discussion Forum
| |-+  Mild Modifications
| | |-+  69 Oil Pressure Gauge
« previous next »
Pages: [1] Print
Author Topic: 69 Oil Pressure Gauge  (Read 1583 times)
mcharter
Newbie
View Profile
« on: August 19, 2011, 03:16:11 PM »
Looking for input on 69 console oil pressure gauge issue.  I am using the correct plastic line from engine to gauge.  I have had the line break twice now, what a mess!  Probably cracked while doing  some other work on the engine.  Does anyone offer a metal replacement line or maybe an electric sending unit?  I suppose an electric sending unit would then need a new gauge, which I would like to match the current gauge.  Anyway, suggestions to prevent another oil bath would be appreciated.
Logged
Gramps69Z
Hero Member
69 X33 D80
View Profile Email
« Reply #1 on: August 19, 2011, 04:26:56 PM »
If installed and routed correctly the plastic line is what should be used. A metal line will flex with vibration and eventually break.
Logged
Captain John Wykoff
Destin Fire     3 to go
I'm sick and tired of mismanagement and disappointment.
I'm a COWBOYS fan.
68Zproject
Hero Member
View Profile Email
« Reply #2 on: August 21, 2011, 01:04:12 AM »
I've had the plastic line on my 68 Z for 3 years and never had a problem.
Logged
68Z28
CRG Member
View Profile Email
« Reply #3 on: August 21, 2011, 10:56:59 AM »
The original nylon line has been in my '69 Z/28 for 42 years and works just fine.
Logged
Ed Bertrand
CRG Member
View Profile WWW Email
« Reply #4 on: August 21, 2011, 12:20:20 PM »
John, you may have just given us the answer! If the original lines were nylon and the repops are plastic, therein lies the problem. Nylon has a much greater ability to bend and is less rigid than plastic, so maybe that's the reason I keep hearing about this issue.
Logged
Ed Bertrand
CRG Member
CRG Member
View Profile Email
« Reply #5 on: August 22, 2011, 10:09:17 AM »
I think everyone is talking about the same thing, and just calling the line "plastic"; technically, it's an Engineering-grade black nylon, but to most folks it's just "plastic".
Logged
mcharter
Newbie
View Profile
« Reply #6 on: August 22, 2011, 10:43:25 AM »
Thanks all for the responces.  The lines I have been using came from Ricks and are black in color so I am assuming from the above they were the nylon material.  In any case I have still had a couple of them break.  They were probably hit or nicked while doing some other work in the area.  They both broke in the engine compartment near the fitting they come out of.  Obviously I will use great care now doing anything in that area of the engine but would like to come up with something a little stronger.  Any ideas?
Logged
Petes L48
Member
View Profile
« Reply #7 on: August 22, 2011, 11:31:41 AM »
Maybe try Grainger or McMaster Carr for suitable tubing.  McMaster usually has good descriptions of the material and strength.  If not showing the car, you could just add a small length of braided sleeve or spring like you see used on some hoses for protection.
Logged
ban617
Member
View Profile
« Reply #8 on: May 03, 2012, 05:31:32 AM »
You could use copper line for the oil pressure
Logged
Stingr69
Member
View Profile Email
« Reply #9 on: May 03, 2012, 11:06:49 AM »
Problem with copper is that it is supposed to be subject to work hardening. The best bet is to purchase the better line kits. Some factory oil pressure guage lines were copper plated steel. See if you can get one of those.
-Mark.
Logged
CRG Member
View Profile Email
« Reply #10 on: May 03, 2012, 01:53:38 PM »
-Mark.
That's correct - DO NOT use copper tubing (GM didn't, for good reason); GM used either tinned steel tubing or copper-plated steel tubing for oil pressure lines when they used metal prior to the introduction of nylon tubing. Paragon has kits with the copper-plated steel lines and fittings.
Logged
Hero Member
View Profile
« Reply #11 on: May 03, 2012, 04:23:15 PM »
I ran a metal line back in my racing days and the only thing I found annoying was it telegraphed engine noises into the passenger compartment.
Logged
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
69pace
Member
View Profile
« Reply #12 on: June 04, 2012, 08:07:20 PM »
I don't trust the reproduction lines available, even the best one I saw for a Corvette.
I am in the process or converting the 69 factory oil pressure gauge face to an electric sender fed gauge.
Logged
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.091 seconds with 18 queries.
