Author Topic: LOS Special Paint Cowl Tag  (Read 50683 times)
« on: August 12, 2011, 10:56:33 PM »
See attached photo...
Re: LOS Special Paint Cowl Tag
« Reply #1 on: August 12, 2011, 11:55:14 PM »
Paul, do you know the VIN?
12E U063
ST 68-12437 LOS 21728 BODY
TR 712 --- Paint
IZRSSS
  • Guest
« Reply #2 on: August 13, 2011, 12:12:12 AM »
Paul - Thanks for posting this tag. First time I have ever seen a 3 dash special paint designation. Evidently it was only used in 68 by LOS/Fisher... Very cool!
http://www.camaros.org/numbers.shtml#ExteriorColors
Ed & Paul - I know you guys know all about decoding, but just in case some don't...
12E - Dec 4Th Week
U063 - 19Th day of the month. 63rd body started that day.
ST - 1968 Coupe
TR - Standard Buckets
« Reply #3 on: August 13, 2011, 12:37:24 AM »
12E U063
TR 712 --- Paint
Ed, the VIN is the photo file name...  8L322467
Your welcome, Marty!
« Reply #4 on: August 13, 2011, 12:56:24 AM »
Paul, is it 124378L322467 or 123378L322467
« Reply #5 on: August 13, 2011, 01:17:57 AM »
Ed, it appears to have been a coupe.  Not much left now.  Too bad as it appears to have been painted a "hugger orange" color as seen on the cowl and other oversprayed areas.
« Reply #6 on: August 13, 2011, 01:23:33 AM »
Paul, 6 cylinder (12337) or V8 (12437)?
And what are you talking about? A little bondo and she'll be as good as new!!
IZRSSS
  • Guest
« Reply #7 on: August 13, 2011, 01:40:26 AM »
Ed - I think the 12437 on the Cowl-T corresponds with the VIN? If so it's a V8, or should I say, was...
« Reply #8 on: August 13, 2011, 01:44:56 AM »
Duh Paul!  68-12437 on the cowl tag tells you it was a coupe...   :-[
Well Ed, going by the motor mount brackets and the accelerator pedal linkage, I'm going with V8.  What do you think?
« Reply #9 on: August 13, 2011, 01:47:58 AM »
Marty, that's '67 only.  Read this...  http://www.camaros.org/numbers.shtml#VINvsStyle
Gramps69Z
  • 69 X33 D80
« Reply #10 on: August 13, 2011, 01:53:46 AM »
Looks like it has disc brakes.
Captain John Wykoff
« Reply #11 on: August 13, 2011, 01:57:27 AM »
Yes it does.  Everything is still there too!
OG69Z
« Reply #12 on: August 13, 2011, 02:04:30 AM »
There appears to be another subframe in the background.
It looks like a good project to me, but my wife doesn't think so :(.
Could you find any original paint on the bottom side of the A-post areas?
Bob
« Reply #13 on: August 13, 2011, 02:12:15 AM »
Quote
That's my guess as well, but I figured if you had the full VIN you could confirm.
Not much left, but original disc brakes are worth $100 or so. The front sub frame another $100 or so.
I also see another sub frame, and a rear axle behind it. What's the code on the axle?
Is this a wrecking yard? The early model Corvair looks like it's a convertible, so there may be some parts on it the EM (Early Model) guys might be interested in.
IZRSSS
  • Guest
« Reply #14 on: August 13, 2011, 02:14:08 AM »
My mistake, I was going off my own Cowl & VIN, both of which have 12437.
« Reply #15 on: August 13, 2011, 02:39:06 AM »
Quote
Sorry Ed, the VIN plate is gone.  Only the partial VIN is there.  See photo below...
The seller doesn't say anything in the listing about the rear axle.
Ed, that's a 1962 Oldsmobile F85 Cutlass convertible.
« Reply #16 on: August 13, 2011, 02:46:19 AM »
From the side it looks a lot like an early Corvair!
Do you have the listing?
« Reply #18 on: August 13, 2011, 04:12:17 AM »
The car was a Z/28 or SS based on the Muncie speedo hole and cable clip.
« Reply #19 on: August 13, 2011, 07:44:18 PM »
Good eye, Jon.
MyRed67
  • SZZLN 67
« Reply #20 on: August 14, 2011, 05:33:49 AM »
Wouldn't the Dual Piston Brakes have only been on SS or Z/28?   Also in pics. shows front bracket for a console, just sayin' this seems to have been a nice optioned car.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Gramps69Z
  • 69 X33 D80
« Reply #21 on: August 14, 2011, 01:35:32 PM »
Optional for SS.
http://www.camaros.org/suspen.shtml#Brakes
Captain John Wykoff
« Reply #22 on: August 16, 2011, 02:12:25 AM »
Yea and Milt's old 68 Tri power Dana Survivor that Kevin S currently owns is the same color... and if I am not mistaken a 67 Z painted that color has just been restored in Maryland...
MyRed67
  • SZZLN 67
« Reply #23 on: August 16, 2011, 04:37:18 AM »
>>>John,  Sooo, were the Dual Piston Brakes optional on anything other than SS and required on Z/28?
1967 Camaro  LOS  11A
« Reply #24 on: August 16, 2011, 07:22:02 AM »
Honestly can you do any?
More importantly
Would you be willing to do any more work to ID if this is a solid lifter LA Special Paint Car?
Just for fun what is the drivers front wheel and tire..
Maybe the firewall has visible chalk marks if wiped with windex?  or lightly scuffed?
Check the Wiper well for signs of white stripes or Black stripes.
Maybe a spring tag or shock tag exists?
AS a side note
The car appears to have been rolled.
Mark
« Reply #25 on: August 16, 2011, 10:29:44 AM »
The top of the firewall between the elephant ears is painted black over the orange body color paint.  Typical of a car equipped with a set of Z28 stripes from the LA plant.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
JoeC
« Reply #26 on: August 16, 2011, 04:33:11 PM »
Dana Chevy liked that color. Their Dana sponsored 68 SS396 drag car was also orange
68 RS/SS Ragtop
    • My fquick e-garage
« Reply #27 on: October 06, 2012, 06:25:29 PM »
I know it seems crazy but I bought it. I envision it as a Hugger Orange 68 RS Z/28. I think most of it will just buff out.
Capt Bob
68 Camaro Convertible owned since 1980.
92 Z28- Who doesn't like a Hugger Orange 3rdGen
02 BlackBird #30- 1 of 2 convertibles built.
http://www.fquick.com/68_RS_SS_Ragtop
vtfb68
« Reply #28 on: October 07, 2012, 02:55:12 AM »
Those TT letters and numbers sure are crisp!
68 08E LA RS Y2 749 L30 M35
Fred Mertz
« Reply #29 on: October 07, 2012, 05:29:05 AM »
It also has a "Muncie" hole in the firewall for the speedo cable.
« Reply #30 on: October 07, 2012, 07:11:18 AM »
  As noted in reply #18 above.
68 RS/SS Ragtop
« Reply #31 on: October 07, 2012, 02:07:05 PM »
I'm in the big sandbox right now, I return Stateside in Dec. I pick it up in Jan, any details of interest anyone want confirmed?
Capt Bob
« Reply #32 on: October 07, 2012, 04:11:37 PM »
Quote
email sent Bob.
68 RS/SS Ragtop
« Reply #33 on: October 07, 2012, 05:31:08 PM »
Quote
email sent Bob.
email replied Ed.
Bob
Capt Bob
« Reply #34 on: October 08, 2012, 08:25:50 PM »
Yup, here's the Camaro...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200639080076&viewitem=&sspagename=STRK%3AMEWAX%3AIT
and here's the Cutlass...
http://cgi.ebay.com/ebaymotors/1962-OLDSMOBILE-F85-CUTLASS-CONVERTIBLE-RARE-MODEL-/200639071247?pt=Salvage_Parts_Cars&hash=item2eb705440f
That Cutlass Convertible would be a nice car to restore for an Olds enthusiast.    That car would have come with a 215 ci ALUMINIUM V8 engine with 185 hp (4 bbl).  Unless I'm mistaken, you could also get either a supercharged or turbo charged version of that engine as an option?
68 RS/SS Ragtop
« Reply #35 on: October 10, 2012, 05:06:47 AM »
[/quote]
Agreed on the COOL car factor. Not hooked in to the Olds scene though. If it's still there, I'll reprt back.
Capt Bob
67rs/ss396
« Reply #36 on: October 20, 2012, 06:17:17 AM »
The sub frame appears to be later (69) than an early 68 car.
67 rs/ss L48 w/headrest org.37k
67 rs/ss L35 w/headrest project
67 rs/ss L35 w/smog org 78k
67 rs/ss L78 O-O -L201C
68 rs/vert L89
« Reply #37 on: October 28, 2012, 09:08:09 PM »
Anyone know what size the center link is?  That would also help clue in potentially what the are was..
Interesting that car was built a week after mine.  Would there have been almost 200 cars built in a weeks time around Christmas & New Years?
« Reply #38 on: October 29, 2012, 04:45:14 PM »
Yes. Van Nuys built 512 cars per day, 256 of which were Camaros. The full week off (from Christmas to New Year's day) didn't start until the early 70's.
« Reply #39 on: October 29, 2012, 11:20:38 PM »
Learned something new everyday.  Thanks.
68 RS/SS Ragtop
« Reply #40 on: December 27, 2012, 01:26:50 PM »
Excited to be home and looking forward to driving out next week to pick this and 2 other subframes up.
Capt Bob
« Reply #41 on: December 27, 2012, 04:05:34 PM »
What's the possibility that Camaro was a Z28?  With the special order paint, Muncie, disk brakes, etc..   it was more than likely a *special model* of some kind.    With that paint code, you could paint the car ANY COLOR you want, and it would be *correct* for judging purposes..  :)
Are you going to restore it?  a few body panels..  it would be good as new.  :)
Gary
68 RS/SS Ragtop
« Reply #42 on: December 27, 2012, 05:45:53 PM »
I thought I'd try to buff it out first. :)   Yes, at one point I think it was a very cool car.  I am going to try to identify what the "special" paint was.
Gary
Capt Bob
HOT3O2
« Reply #43 on: December 27, 2012, 09:17:49 PM »
Great story Bob. Make sure you keep us updated. :)
Rick
69 RS/Z28
« Reply #44 on: December 28, 2012, 01:59:33 AM »
In looking at those photos, I noticed that the driver side engine mount has one of the attaching bolts coming up from the bottom (with the nut on top);  I recently found that same bolt on my car in the same cirection (opposed to all the others);  Is that the way all the cars were for some reason, OR does it just mean if  the bolt was ever removed, it was easier for the owner/mechanic to reinsert if in that direction???
Gary
68 RS/SS Ragtop
« Reply #45 on: January 10, 2013, 12:21:19 PM »
After a week delay, I'm finally here.
Capt Bob
68 RS/SS Ragtop
Capt Bob
« Reply #47 on: September 05, 2013, 05:55:57 AM »
I think you're right, Bob.  Tangerine Orange looks like the correct color.   :)
68 RS/SS Ragtop
« Reply #48 on: September 05, 2013, 11:51:06 AM »
From what i find, that color was not available for other Chevy models that year? I wonder where it came from and why. Also, the eBay car is a Norwood, and mine is LOS built 8 months apart.
Capt Bob
« Reply #49 on: September 07, 2013, 01:54:29 AM »
I thought the orange from the factory was from the GM truck fleet line .?.  It's that what Dana used?
« Reply #50 on: September 07, 2013, 01:11:45 PM »
wow put that with the 67 Orange no stripe Z28 that was restored (albeit with stripes) a couple of years ago... what a pair!
68 RS/SS Ragtop
« Reply #51 on: September 07, 2013, 06:33:10 PM »
Thanks for the lead- it lead to finding this link:
http://corvettes-musclecars.com/Supercars/68Dana
Capt Bob
« Reply #52 on: September 08, 2013, 12:38:10 AM »
This is the one Lucas Restorations did- as far as I remember they never found any remnants of stripes.
« Reply #53 on: September 19, 2014, 12:41:12 AM »
Has the NCRS package been requested on this car?
If so where was the car delivered?
Classic Gary
« Reply #54 on: September 25, 2014, 04:51:21 AM »
Do I see a rally green ralley sport z28 in the making?
opinions are like wallets, some just aren't worth stealin'.
68 RS/SS Ragtop
« Reply #55 on: December 01, 2014, 12:14:47 AM »
Every time this one pops up, it makes me want to resurrect the one I got. Really cool color, really cool car.
http://www.ebay.com/itm/Chevrolet-Camaro-Z-28-1968-camaro-z-28-z-28-302-v-8-4-speed-muncie-m-21-manual-custom-paint-/311187009329?forcerrptr=true&hash=item487430ef31&item=311187009329&pt=US_Cars_Trucks#ht_41399wt_1107
Funny how a 3 Owner car now becomes a 1 owner car.
Here's the listing from ebay a little more than a year ago when it was a 2 owner car- $50,000.
HELLO,THIS ONE OF A KIND CAR,1968 Z28 CAMARO, IS UP FOR SALE BY MY MOTHER IN LAW. MY WIFES FATHER PASSED AWAY LAST YEAR AND THIS WAS HIS PRIDE AND JOY SINCE IT WAS NEW. I AM LISTING  IT FOR HER ,SO IF ANY QUESTIONS PLEASE FEEL FREE TO EMAIL ME AND I WILL TRY TO GET ANSWERS AS FAST AS I CAN FROM HER.
FIRST OFF ,THIS IS A 2 OWNER CAR,MY FATHER IN LAW BOUGHT THIS CAR IN 1968 WITH ONLY 100 OR SO MILES ON IT.DONT KNOW THE WHOLE STORY WHY THE FIRST OWNER HAD TO SELL IT.
THIS CAR WAS APPRAISED BY JERRY MACNEISH-CAMARO HI-PO INC. ELDERSBURG MARYLAND.CERTIFIED APPRAISER ,IAAA ID#1007319906   WWW.Z28CAMARO.COM         HE IS ALSO A CERTIFIED DIAMOND JUDGE,AMERICAN CAMARO ASSOC.,TECH ADVISOR,INTER. CAMARO CLUB
SPECS :    VIN# 124378N409142
                  BUILD DATE: 04A          NOR#: 108641       TRIM CODE: 712
                  ENGINE: V0308MO ASSM DATE,18N409142 DECK,3914678 BLK,CAST C18,ORIG 302
                  TRANS: P8C21 ASSM DATE,660 CASE,18N409142,MUNCIE 4 SPD,ORIG
                  REAR AXLE: BV0321G ASSM DATE,12 BOLT,4:10 POSI,DATE B298,860NF HOUSING,ORIG
                  DOCUMENTATION: PROTECT O PLATE,WINDOW STICKER,PURCHASED NEW FROM GRABIAK CHEVY,NEW ALEXANDRIA PA
                  PAINT COND: EXCELL ORIG ,SPECIAL ORDER WITH FACTORY STRIPE DELETE,TANGERINE ORANGE
                  INT COND: EXCELL ORIG,BLACK,STANDARD BUCKET SEATS,ONE OF THE NICEST ORIG THAT IVE SEEN-JERRY
                  ENGINE BAY: VERY CLEAN AND ORIG, SURVIVOR QUALITY,MINOR MAINT ISSUES,SMOG REMOVED
                  UNDER CARRIAGE: EXCELL ORIG FLOORS,PAINTED AND TOUCHED UP,NO RUST,NEED GD CLEANING
THIS 68 CAMARO HAS BEEN CERT BY CAMARO HI PO. ACCORDING TO OUR DATA BASE AND HISTORIC CHEVY RECORDS,THIS CAR IS AN ORIG Z28 302-290 HORSE,4 SPD MUNCIE TRANS,12 BOLT REAR. THE CAMARO ,DRIVE TRAIN AND TRIM TAG ARE CERT.AS REAL AND AUTHENTIC.THE INT AND EXT. COLORS ARE CORRECT AND MATCH THE TRIM ID TAG . SUMMARY,THIS CAR FALLS INTO THE ALL ORIG SURVIVORS CATEGORY.ONLY 7,199 1968 Z28S WERE MADE MAKING IT VERY COLLECTABLE. ALL DRIVE TRAIN STAMPINGS MATCH ALL ORIG 68 STAMPINGS IN THE CAMARO DATA BASE. LOW MILEAGE Z28S ARE RARE! WHAT MAKE THIS Z28 EXT RARE IS YHE SPECIAL ORDER TANGERINE PAINT AND STRIPE DELETE. TO DATE ,I HAVE NEVER SEEN ANOTHER 1968  Z28 LIKE THIS CAR. THIS IS ONE OF A KIND X28. ORIG MILES 22220.
THIS IS PRINTED ON THE APPRAISAL REPORT.
YOU CAN GET JERRY MACNEISH CREDENTIALS FROM THE WEBSITE MENTIONED ABOVE
ISSUES WITH CAR PER JERRY: HOOD PAD ADDED,SMOG REMOVED,HURST SHIFTER REPLACED ORIG MUNCIE SHIFTER,RADIATOR HAS BEEN RE-CORED,UPPER RAIL IS NOT CORRECT,REPLACEMENT STARTER,SOME MINOR SPRAY TOUCH UP UNDERNEATH-NEEDS GD CLEANING,FUEL TANK NEEDS CLEANED,CAR NEEDS A GARDNER CONCOURS EXHAUST SYSTEM-DOES HAVE NEW ONE ON IT IN THE PAST YEAR-I THINK MY FATHER IN LAW USED YEAR ONE???,,LOWER REAR VALANCE MINOR DENT,TIP OF RADIO MAST IS MISSING,RIGHT SIDE RUBBER COWL AREA PLUG MISSING-STILL AVAIL FROM GM, ENGINE HOSES AND CLAMPS HAVE BEEN CHANGE
CAR DOES NEED A NEW MASTER BRAKE CYLINDER,AND HAS SOME SCRATCHES AND STONE CHIPS AND A FEW SMALL DENTS-AGAIN THIS CAR IS A SURVIVOR AND 45 YEARS OLD,BUT WELL WORTH IT AND 1 OF A KIND!!
OPTIONS: A02 TINTED WINDSHIELD,D80 SPOILER EQUIP,G80 POSI-4:10 GEARS,J52 POWER DISC BRAKES,M21 MUNCIE 4-SPD TRANS,U63 AM RADIO,Z21 TRIM GROUP,Z23 SPECIAL; INT GROUP,Z28 SPECIAL ENGINE AND EQUIP PACKAGE,1001HA SPECIAL ORDER PAINT
COMPONENT DATA: ORIG 9078 BRAKE BOOSTER DATED 89TH DAY OF 1968,HIDDEN VIN STAMP IN COWL AREA ORIG,ORIG "OD" RADIATOR DATED C,111467 DISTRIBUTOR,DATED 8B8,1100814 ALTERNATOR,DATED 8C22,VOLTAGE REG DATED 8D,FAN CLUTCH DATED 2-1-68,SIDE MIRROR 8DM17,CARB 4053 DATED 833,BUMPER JACK DATED 8C, DF WHEEL DATES,LARGE FONT LETTERS EARLY STYLE WHEELS, WINDSHIELD DATED VZ, DEC. 1967, DRIVERS DOOR,XX FEB 1968, PASS DOOR YZ OCT 1967, RIGHT SIDE 1/4 WINDOW XX FEB 1968, LEFT SIDE 1/4 WINDOW OCT 1967, REAR WINDOW LX,MAR 1968
I BELEIVE THAT MY WIFES FATHER STILL HAS THE ORIG TIRES THAT CAME WITH THE CAR.
Now Listed as $159,000:
1968 Chevrolet Camaro Z/28 – The Real Deal
Are you looking for a collector vehicle that will garner attention and admiration from all who see it? Are you a Camaro enthusiast searching for your Holy Grail car? Stop searching – we found it for you, and it’s right here in our showroom at Blue Marlin Motors USA!
This is an original, documented, one owner 1968 Camaro Z/28. How do we know it’s one owner, you ask? The original Protect-o-Plate warranty card and book are still with this car.
The VIN of this rare Camaro is 124378N409412.
The block casting number is 3914678, which authenticates the engine block as one belonging to a 302 cubic inch 290 horsepower V8 intended for a 1968 Camaro Z/28. The engine deck, as you can see in the photos, is stamped with a partial VIN stamp that reads 18N409412, verifying that this DZ 302 engine belongs in this particular 1968 Camaro Z/28.
The Muncie M21 4-speed manual transmission mated to the engine is also original to the car. Its assembly date is P8C21, it sports a “660” case, and again the partial VIN of 18N409142 is stamped into the case as well. The 12-bolt posi-traction rear end has original 4.10 gears and an assembly date code of BV0321G, a casting date of B298, and a housing number of 860NF. It, too, is original to the car.
What really sets this car apart from the pack, aside from the fact that it’s only got 22,220 original miles, is its paint. The paint code was a special order, as evidenced by the “1001HA” code on the window sticker, as well as the “- -“designation for paint on the car’s original trim tag. This special order car was ordered and painted in a special hue called “Tangerine orange.” In addition to that, it is a real factory stripe delete car, and the paint on this car is original.
This car has been certified by Jerry MacNeish of Camaro Hi-Performance, INC – known worldwide as the authority on the 1967-1969 Camaro Z/28. It is a true survivor Camaro. The only changes from the day this car left the factory during the first week of April 1968 are minor. There is a Hurst shifter in between the bucket seats, and the smog pump, long known as a failure item and a concern on these cars, was removed sometime early in its life. Everything else is date-code correct for the car, making this quite possibly the most original Z/28 Camaro you will ever see.
A complete list of the codes will be below this description for your review.
If you want to add this piece of history to your collection, come see it in person here in our showroom. Blue Marlin Motors is close to Palm Beach International airport, and we’ll be happy to help you make arrangements to see the car from anywhere in the world.
Blue Marlin Motors can also assist you in finding financing for this or any other of our classic and collector cars in inventory. With rates as low as 2.5% from some of our favorite credit unions, and classic cars appreciating on average about 6% per year, financing a classic car is just money in the bank! Give us a call for more details!
-Team @ Blue Marlin Motors USA
Capt Bob
« Reply #56 on: March 11, 2015, 03:28:06 PM »
Whatever happened to this car in the original post?  Did anyone run the NCRS report on it?  Any new info?
TangoBravo
« Reply #57 on: December 26, 2015, 04:56:08 PM »
Very curious also here- what has become of this Camaro- could be the 68 Dana drag car?? Something tells me this one is important.
712 interior may nix the Dale Armstrong car though.
JKZ27
« Reply #58 on: June 26, 2016, 12:26:13 AM »
Well, this partial former car was in Frederick, MD this weekend. Cowl only. No frame or anything else. Not sure why he had it there, maybe just a conversation piece. Trim tag is no longer attached.
John
68 RS Ash/Ivy Gold 327EFI M20
68 RS/SS Ragtop
« Reply #59 on: December 26, 2019, 03:44:19 PM »
Sorry I have not followed up on this. Yep, it was at the 2016 Nat's and I brought it as a conversation piece along with my unfinished 68 convertible. I think I did offer to sell it to one guy who passed on a great deal and story.
When I picked this up I removed the partial vin from the trunk (axle hump) and cowl as well as the TT. I did not want to be towing around a rental trailer full of partial cars for 1100 miles and have some overzealous POPO turn it into GTA. This was an eBay purchase, the owner lived in FL, the parts were in OK and everything was heading to SC. I had no title or even a bill of sale. All I had was a printout from my computer showing an eBay transaction. Call me paranoid, but I mailed the vins and TT home.
I have the cowl back to the shifter opening (Anything that showed color), the sub-frame with brakes, as well as the partial vins and TT. It proudly resides on the wall of my buddy's shop who likes to tell everyone he's storing a DANA for a friend. If there becomes a legal way to resurrect the vin plate I'd love to see this come back to life as a Safety (Tangerine) Orange Z/28, but for now it's just another internet story.
Capt Bob
